Live most of this week (5/4 - 5/9)
Post your streaming time/info here, so people know when you're printing live
gestalt73
Postby gestalt73 » Sun May 04, 2014 5:58 pm
Updating the link, swapping from google hangouts to personal host, apparently google hangouts will only idle for 90 minutes before it shuts down.
http://104.35.230.74:8080/stream_simple.html
Printing 6x6 topography maps for college students, then two large, full bed prints for a client.
First time sharing this, I saw someone post that geneb had a livestream going full time as a sticky, but I couldn't find it. In the future, is there a default livestream that we can attach to and share with at will?
For whatever reason the screen share is mirroring the image, but other than that it looks good.
I'll be printing almost continuously all week, and I'll check in periodically and answer questions and take tips. :-)
Alan
Tinyhead
Re: Live most of this week (5/4 - 5/9)
Postby Tinyhead » Sun May 04, 2014 8:43 pm
That's pretty cool! I like the view too.
Out of curiosity, is your effector made from PLA or ABS? And have you had any issues with the balls coming loose from the build plate heat?
gestalt73
Postby gestalt73 » Sun May 04, 2014 10:50 pm
You know, funny story, I was losing balls left and right using the heated build chamber.
I tried jbweld, jbquick, and nothing worked.
Then I came across a few mentions of people using Loctite Ultra Gel Control Super Glue.
Haven't lost one since.
I suspect strongly that the temperature increase slightly increased the diameter of the bearings, which caused the jbweld to lose its grip.
The effector pieces are all printed in ABS.
Tinyhead
Postby Tinyhead » Mon May 05, 2014 10:51 am
Well I'm definitely going to try and find some of that Loctite. I've lost a few balls myself already (and badly warped my PLA effector) going close to the build plate. I completely agree with the thermal expansion. When I first did the mod, I made about 18 ball/screw assemblies and took a flame to the ball gently for about 1.5 seconds and it flies right off. Now I've got the hot end well below the effector, but I'm losing almost 3" of build height.
Thanks for the suggestion! Time to cut up some more bearings to get those 3/8" balls!
gestalt73
Postby gestalt73 » Mon May 05, 2014 12:00 pm
Yeah, I've been running like this for several months now, and the loctite hasn't dropped a ball. not once. I print ABS and keep my bed at 100c.
I have no idea about which other ones work, maybe they all will, but here is the exact loctite that I used:
http://www.loctiteproducts.com/p/4/3/sg_ug_cntrl/overview/Loctite-Super-Glue-ULTRA-Gel-Control.htm
gestalt73
Postby gestalt73 » Mon May 05, 2014 2:55 pm
Next print job started, it's a 6x6 topography plate. 10 hour print.
gestalt73
Postby gestalt73 » Tue May 06, 2014 2:27 am
Next print job started, it's another 6x6 topography plate. 11 hour print.
Postby Eaglezsoar » Thu May 08, 2014 7:23 am
That must be an amazing glue if it works and epoxy fails. Definitely going to have to get some.
Thanks for the tip!
Return to “Live Stream Announcments”
Who is online
