Rev3 Onyx on 48V?
Check out how others are building and modding their own heated beds
doctorgonzo
Rev3 Onyx on 48V?
Postby doctorgonzo » Tue Mar 17, 2015 1:29 pm
I have a 48V 7.3A power supply kicking around. Any reason I can't run my Onyx on this with a SSR?
Chris
(not an electrical guy)
Tincho85
Re: Rev3 Onyx on 48V?
Postby Tincho85 » Tue Mar 17, 2015 1:55 pm
48v omg... don't know really, but I think you need more amps.
Martín S.
Tonkabot
Postby Tonkabot » Tue Mar 17, 2015 2:11 pm
It will draw way more current than you have available. burn out your 48v supply or blow fuses/breakers...
doctorgonzo
Postby doctorgonzo » Tue Mar 17, 2015 2:15 pm
V=IR is a bummer.
mvansomeren
Postby mvansomeren » Tue Mar 17, 2015 2:16 pm
I'm thinking that it will take down the electrical grid in Atlanta :lol: Seriously, though, even with a voltage regulator to get it to the proper voltage, you'll need more available current than the power supply has. The results will probably result in the smoke escaping. And once it's out, you'll never be able to get it back in.
ULTIMATE 3D JEDDI
Postby Jimustanguitar » Tue Mar 17, 2015 2:39 pm
Yeah, unless that supply is an expensive current limiting one, an Onyx at 1 ohm will overdraw that supply by a factor of 7 or 8.
Back to the drawing board.
doctorgonzo
Postby doctorgonzo » Tue Mar 17, 2015 3:05 pm
http://www.amazon.com/Genssi-14-6A-Regu ... B005CLDOW8
I have one of these too, is it gonna be enough?
0110-m-p
Postby 0110-m-p » Tue Mar 17, 2015 3:22 pm
doctorgonzo wrote:http://www.amazon.com/Genssi-14-6A-Regulated-Switching-Supply/dp/B005CLDOW8
You really need a 20A+ 24V power supply to run a R3 Onyx directly.
Most R3 beds are a little above 1-ohm (why they are being sold for cheaper since they have too high of a resistance to generate the power/heat required on 12V). So if resistance=1.2ohm and you have a 24V power supply, V=IR says that you need a power supply that can supply 20A.
EDIT: Also a good tip...when you double the voltage of a heater you quadruple the power requirements.
KAS
ULTIMATE 3D JEDDI
Postby KAS » Tue Mar 17, 2015 3:42 pm
Don't feel bad, I have a 1300w 65v Toroidal power supply I cant use either.
It's looking like SP-750-24 is the magic power supply to find.
doctorgonzo
Postby doctorgonzo » Tue Mar 17, 2015 3:52 pm
KAS wrote:Don't feel bad, I have a 1300w 65v Toroidal power supply I cant use either.
The Meanwell SP-750-24 is $200 :shock:
JFettig
Postby JFettig » Tue Mar 17, 2015 10:48 pm
Or $50 on eBay
Return to “Heated Bed How-To's”
Who is online
