Crydom Failure
Check out how others are building and modding their own heated beds
noventix
Crydom Failure
Postby noventix » Tue May 31, 2016 9:23 pm
Hi experts
I am trying to wire up a Meanwell 24V power supply, along with a Crydom D1D40 and a 24-12V converter. The converter is working great and the Rambo works as expected, but the Crydom is not operating right. It is registering 24V regardless of whether it is getting a signal or not. Even with nothing connected on the input side, there is 24V present on the output side.
Is the SSR fried? Sadly I bought this used from eBay so am suspecting a faulty unit. I have double checked my wiring and am sure it is all wired correctly. This is someone else's image, but is how I am wired up.
Rostock Max V2. E3D V6 Hotend. E3D Titan Extruder. TrickLaser Carbon Fiber 300mm Arms. TrickLaser MaxMetal Platform. TrickLaser Trick Trucks. TrickLaser Heat Spreader. TrickLaser LED Light Ring. MeanWell SP-500-24. Simplify3D.
ULTIMATE 3D JEDDI
Re: Crydom Failure
Postby Xenocrates » Tue May 31, 2016 10:03 pm
You've likely bought a cheap clone with a fake badge, if not an outright fake. The Bay of thieves is a bad place to buy low bulk high price parts like SSRs. instead, I suggest you buy a http://www.auberins.com/index.php?main_page=product_info&cPath=2_30&products_id=288. They are cheap, and known to work well, even without a heatsink. Mike and several others use them, and they are more than rated for what you're doing.
DeltaCon
Re: Crydom Failure
Postby DeltaCon » Wed Jun 01, 2016 6:40 am
Oeh... Wish I knew that before. I have a Crydom laying around waiting for the next upgrade-time, and got it through ebay as well. I choose the Crydom because it is well advised in this forum. Hop I have a good one...
Rostock V2 / E3D V6 / Raymond Style Heatchamber on the way!
noventix
Re: Crydom Failure
Postby noventix » Wed Jun 01, 2016 6:51 am
Xenocrates wrote:You've likely bought a cheap clone with a fake badge, if not an outright fake. The Bay of thieves is a bad place to buy low bulk high price parts like SSRs. instead, I suggest you buy a http://www.auberins.com/index.php?main_page=product_info&cPath=2_30&products_id=288. They are cheap, and known to work well, even without a heatsink. Mike and several others use them, and they are more than rated for what you're doing.
I was worried about that with eBay. Lesson learned. I will check out that unit. Thanks!
ULTIMATE 3D JEDDI
Re: Crydom Failure
Postby Eaglezsoar » Wed Jun 01, 2016 12:29 pm
The advice from Xenocrates is spot on, I use what he recommends and have no problems.
Those cheap ssr's you find on Ebay have even caught on fire and are NOT recommended for any use.
KAS
ULTIMATE 3D JEDDI
Re: Crydom Failure
Postby KAS » Wed Jun 01, 2016 5:17 pm
I'm using the Crydom D1D40. I'm sure it can be found cheaper, but I trust Mouser more than ebay.
http://www.mouser.com/ProductDetail/Cry ... j0cw%3D%3D
noventix
Re: Crydom Failure
Postby noventix » Wed Jun 01, 2016 9:30 pm
Thanks for the advice all ... I hope at least others can learn from this and avoid eBay for these types of items. The alternative that Xenocrates listed was out of stock, so I ordered a brand new Crydom D1D40 from Arrow Electronics. It should be here by Friday so the build can continue.
I love these forums!
gchristopher
Re: Crydom Failure
Postby gchristopher » Wed Jun 01, 2016 11:09 pm
Ouch, sorry. The dinosaurs also went with Mouser for a Crydom D1D40. The results were great.
noventix
Re: Crydom Failure
Postby noventix » Thu Jun 02, 2016 9:22 pm
LOVE the dinosaur build! Can't believe I have not seen that before. Will be referencing that when my replacement Crydom arrives. Thanks!
noventix
Re: Crydom Failure
Postby noventix » Thu Jun 09, 2016 8:41 pm
I am happy to report that the Crydom from Arrow Electronics works great. Looking at the new one side-by-side with the old, it is now easy to see it was a fake.
Do NOT buy one of these from eBay.
IMBoring25
Re: Crydom Failure
Postby IMBoring25 » Thu Jun 09, 2016 9:17 pm
In fairness, Crydom has gone through a few different mostly-cosmetic revisions of that SSR. Just looking different doesn't mean the other one was a fake (especially since it was used and would likely have been an older version)...But it doesn't mean it wasn't either.
noventix
Re: Crydom Failure
Postby noventix » Thu Jun 09, 2016 9:40 pm
Good point. It is quite possible this was a legit unit. I think the message here is that given the importance of this component, it is probably worth the investment in getting a new one from a reputable source.
Return to “Heated Bed How-To's”
Who is online
