WHAT WITCHCRAFT IS THIS?!
ULTIMATE 3D JEDDI
Post by geneb » Sun Nov 08, 2015 3:32 pm
MUAHAHAHAHAHAHA!
forrie
Re: WHAT WITCHCRAFT IS THIS?!
Post by forrie » Sun Nov 08, 2015 3:35 pm
What's this.. a new stock power supply?
ULTIMATE 3D JEDDI
Post by geneb » Sun Nov 08, 2015 3:40 pm
I could tell you, but then I'd have to make you use a Makerbot. :D
ULTIMATE 3D JEDDI
Post by Xenocrates » Sun Nov 08, 2015 5:30 pm
If that's a 24V power supply stock, then I am very much want. Although I wish it weren't using a side panel for the plug, ETC, as I like clean lines, and also kinda planned to have a cable duct living on the two non-door sides.
ULTIMATE 3D JEDDI
Post by Mac The Knife » Sun Nov 08, 2015 6:06 pm
The 12 volt supply works very well also. Alot better then a PC PSU. I cannibalized a powersupply for the back panel, for the power cord, and used the kits power switch to switch the mains.
KAS
ULTIMATE 3D JEDDI
Post by KAS » Sun Nov 08, 2015 6:20 pm
Slots in the base are different from the v2.
Of course the images give away the instruction changes, specifically:
fig6.8-1 & fig18.4-5
IMBoring25
Post by IMBoring25 » Sun Nov 08, 2015 6:21 pm
You can print covers for the LED PSUs. Designed appropriately, you can integrate them however/wherever you want. My Mendel came with one, then I designed one for a 30A upgrade and then one for a 24V upgrade
bot
Post by bot » Sun Nov 08, 2015 6:29 pm
I wish they made 24v ATX PSUs.
*not actually a robot
Return to “The Build Zone”
