Max V2.ORNG!
VF_
Re: Max V2.ORNG!
Post by VF_ » Wed Apr 08, 2015 4:37 am
Thanks guys!
@Jassper, that looks very nice. I have yet to find a source for a negative orange/amber display but I am still looking.
ULTIMATE 3D JEDDI
Re: Max V2.ORNG!
Post by Eaglezsoar » Wed Apr 08, 2015 10:22 pm
Jasper, do you remember the source for the yellow lcd?
VF_
Re: Max V2.ORNG!
Post by VF_ » Mon Jul 13, 2015 7:28 pm
Last week I was randomly checking ebay, looking for that elusive negative orange LCD when lo and behold, I found it back in stock at the same company I linked previously in the thread. Today, it finally arrived.
MY PRECIOUS!!1!
Out with the old, in with the new.
I looks sort of amber because I had to up the exposure on the camera a bit, but in reality it is dimmer and a very nice shade of orange.
Besides adjusting the contrast potentiometer on the Smart Controller to make it a bit brighter, no other modifications were needed.
Next on my list: magnetic arms! Stay tuned... :D
ee91137
Re: Max V2.ORNG!
Post by ee91137 » Mon Jul 13, 2015 7:53 pm
Hi VF_,
Can you post a video of the Printer with dampers noise?
How did you cut the carbon fiber textured vinyl ?
Also I would like to see a picture of the Power and led ON...
VF_
Re: Max V2.ORNG!
Post by VF_ » Mon Jul 13, 2015 8:06 pm
You can find quite a few videos on YouTube with machines that have the Astrosyn dampers installed, but this video convinced me to get mine. The power button LED is actually on in the last image I posted, it's not very bright. The carbon fiber textured vinyl was first attached to the plate and then I carefully cut the excess and the various holes with a sharp cutter. I used an Olfa cutter, but any XActo equivalent will do just fine as long as the blade is ultra sharp so it doesn't stretch (or worse, rip) the vinyl.
bvandiepenbos
Re: Max V2.ORNG!
Post by bvandiepenbos » Mon Jul 13, 2015 9:09 pm
VERY nice build! I love the neat wiring and attention to detail.
very Trick looking.
ee91137
Re: Max V2.ORNG!
Post by ee91137 » Mon Jul 13, 2015 9:42 pm
Thanks
I would like to see a video of your printer working...
VF_
Re: Max V2.ORNG!
Post by VF_ » Tue Jul 14, 2015 2:07 pm
bvandiepenbos wrote:VERY nice build! I love the neat wiring and attention to detail.
very Trick looking.
Thanks, Brian! That pushed the overall build time just a liiiittle bit over what the manual suggested :D
ee91137 wrote:I would like to see a video of your printer working...
As soon as I get a chance to make one, I'll post it here :)
AussieBlake
Re: Max V2.ORNG!
Post by AussieBlake » Thu Aug 13, 2015 4:51 am
Hi! Love the build! Where did your source the wiring protector that hangs down from your top plate into the build area... For the life of me I cant find anything like it and I want to find one.
Keep up the good work!
EskimoRuler
Re: Max V2.ORNG!
Post by EskimoRuler » Fri Aug 14, 2015 10:21 pm
AussieBlake wrote:Hi! Love the build! Where did your source the wiring protector that hangs down from your top plate into the build area... For the life of me I cant find anything like it and I want to find one.
I don't think these are the exact ones, but I was just at Ace Hardware and I saw these. These are supposed to be for air hoses but should work the same. They had multiple diameters. I grabbed a 1/2" one just to see how it fits.
Most likely overkill, but I just happened to stumble upon them so thought I'd let you know
http://www.flexzilla.com/air/reusable-fittings-splicers/
VF_
Re: Max V2.ORNG!
Post by VF_ » Sat Aug 15, 2015 4:53 am
Hey, thanks! KSS Wiring - EGRWW16SR Cable Gland is the exact part that I have used on my machine, although I got mine from a local shop. If you can't find that exact model, I'm pretty sure any cable gland with similar specs will do.
EskimoRuler wrote:I don't think these are the exact ones, but I was just at Ace Hardware and I saw these. These are supposed to be for air hoses but should work the same. They had multiple diameters. I grabbed a 1/2" one just to see how it fits.
Those look nice indeed but the aluminum nut seems to snap all the way into the bend limiter, leaving no room for the thickness of the top plate. How did you attach it?
AussieBlake
Re: Max V2.ORNG!
Post by AussieBlake » Sat Aug 15, 2015 7:17 pm
No worries, I'll have to see what I can source in NZ, but I'm sure any electrical shop should be able to help me out. Thanks again!
VF_
Re: Max V2.ORNG!
Post by VF_ » Tue Aug 18, 2015 1:30 pm
AussieBlake wrote:No worries, I'll have to see what I can source in NZ, but I'm sure any electrical shop should be able to help me out. Thanks again!
No problem! :)
Return to “The Build Zone”
