Increasing build size?
thenewguy
Post by thenewguy » Mon Apr 03, 2017 1:08 am
Let's say if I wanted to make a bigger printer using the same effector plate and carriages as a Rostock max while making longer arms and a bigger frame. How wide could I get my print area before I run into problems? Reason is aftermarket parts from say tricklaser and others are good to work with.
Just curious because it would be nice to get in the 400-450mm range for width.
KAS
Re: Increasing build size?
Post by KAS » Mon Apr 03, 2017 10:43 am
Something like this delta calculator might give you a better idea of the frame/arm sizes to match your desired print area.
http://www.thinkyhead.com/_delta/
KAS
Post by KAS » Mon Apr 03, 2017 10:47 am
also here is a Kossel frame calculator.
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
Return to “The Build Zone”
