Precision Plasma LLC 4'x3' table build thread
CaptainMerica
Post by CaptainMerica » Wed Feb 22, 2017 6:01 am
While I'm waiting for parts to arrive to complete the next big upgrade steps on our Rostock V3, I picked up this kit for a CNC plasma table that a friend had bought several years ago and never completed. When completed, it's a 4'x3' table with slide-through, so you can cut from a 4'x8' sheet in 3' increments if needed.
The kit name may not be listed anymore, but they still sell similar kits over at https://www.precisionplasmallc.com/
One of the issues that stopped my friend from moving forward with it was the cost of the electronics kit, as it was suggested to go with the roughly $2000 BladeRunner Dragon Cut 620-4 https://www.candcnc.com/store-home/bladerunner-dragon-cut-620-4/
The other issue was the cost of the plasma cutter, and a big enough air compressor to feed it for long cuts. Luckily we already had a Hypertherm 380 plasma, and a 6hp 60gal air compressor, so the cost-to-complete would be much lower for us.
After searching around, I settled on this kit of all the electronics (minus torch height controller - optional, maybe someday):
https://www.amazon.com/axis-stepper-motor-Driver-DM542A/dp/B00WSI6VO6/
4 pcs Nema 23 stepper motor 425 oz.in bipolar with dual shaft, 8mm & 1/4" (kit included 1/4" ID gears for the racks)
4 pcs Stepper motor driver DM542A, PEAK 4.2A, 128 micsteps
2 pc Power supply 350W-36vdc/9.7A
1 pc parallel cable & 1 pc breakout board
We got the above kit from the same seller off eBay for $260 shipped, so for the savings compared to the $2000 DragonCut, I'll take the chance on this. The instructions specified needing motors with 273 oz-in of torque minimum, so I feel like we'll do just fine with these motors. We're picking up all the 2x2" steel tube tomorrow for welding the framework together, and I still have to pick up the table slats from my friend (they aren't pictured, but were included as an option in this kit). Hardest part so far has been cleaning out room in the workshop for where this will go, which means doing some much-needed shop repairs/upkeep while we're at it. I hate putting up ceilings!
Photos:
Spoiler:
CaptainMerica
Re: Precision Plasma LLC 4'x3' table build thread
Post by CaptainMerica » Fri Feb 24, 2017 12:29 am
Some more pictures of progress being made. I have been working on getting the PC put together with a freshly installed Windows XP 32-bit on there to run the Mach3 software, and I have started looking at laying out the enclosure for the power supplies and stepper controllers. I picked up a nice cheap sheet metal toolbox from Menards that will be great for fitting all the components together as pictured below, once the toolbox is mounted vertically (like on a leg of the plasma table) so the fan blows cooling air up through a windtunnel of all the components and out some holes to be added on the top. I will need to come up with some internal standoff structures for everything to mount to, since I don't want to run screws through the body of the enclosure and look awful on the outside. The motor wires will probably each plug into their own 4-pin bulkhead plug connector on the topmost surface of the completed box, but I still have to identify what ones to order for that.
Photos:
Spoiler:
For wiring, I found a nice outlet with built-in switch, which I can mount approximately as shown and wire the power in series through its own switch, to then feed the PSU's which each feed two of the stepper motor controllers. I will need to wire in a small 12vdc adapter inside the case to run the cooling fan, unless I can find a 120vac fan of around the same size. The fan would mount inside the box, it's just pictured external as there's no holes cut yet. Bringing power in through the outlet, I had to fabricate the male-to-male power cord shown below.
Okay, I know from photos of how to wire the power connection on the Rostock MAX V3, that the black wire ends up coming off of this side of a cable with this shape, so I set the meter to Ohms to identify which part of the plug connects to that.
Photo:
Spoiler:
Now I cut two power cables from the tumbleweed of spare cables / wires in the garage, and it turns out the colored insulation will make this way easier:
Photo:
Spoiler:
Now we need to figure out, once plugged into the outlet we're using as the power connector on the enclosure, where does that pin come out so we know where the black wire comes off? Well, turns out the GFCI on this can only be reset when power comes in "the right way" so I took another power cable (this one already with an end cut off by the helpful puppy) and wired up at my best guess of which terminals hopefully weren't on the same circuit. Wanting to play it safe, I figured I would plug this into a GFCI outlet in my kitchen so I had a mini-breaker right there. A quick test to confirm that the wall outlet's GFCI would pop informed me that yes it would, and it would cut power to other outlets in the kitchen, like the one the pc was plugged into and nearly (but not completely) finished installing Windows. So that process got started over again, and I took it to test coming off of a GFCI outlet in a different room of the house, to avoid that same mistake again:
Photo:
Spoiler:
After plugging it in powered from the terminals on the back, I was able to reset its GFCI to connect everything, and then swap to the other power cable and get the photo above. Now that its GFCI is un-tripped, I unplugged it from power and proceeded to measure Ohms to check continuity of what pin to what terminal, and how the switch operated, so I think I have a good feel for where the ground, positive, and other positive wire will connect once I cut the opening and mount this into the box. Making good progress, and no electrocutions or fires yet! When it comes to my understanding of AC wiring, I'm reminded of the quote from Top Gear about the Stig: "He only knows TWO facts about ducks, and they're BOTH wrong."
joe
Post by joe » Fri Feb 24, 2017 7:16 am
Good Lord, I hope your life insurace is paid up.
ULTIMATE 3D JEDDI
Post by geneb » Fri Feb 24, 2017 7:42 am
It's kind of like hunting for mines by sticking your fingers in your ears and stomping around randomly. :D
Qdeathstar
Post by Qdeathstar » Fri Feb 24, 2017 4:10 pm
Hi.
As a master electrician, I'd say your design looks questionable at best, life threatening at worst. Hopefully you atleast bonded the case of the toolbox to ground.
Return to “The Build Zone”
