Foshon's Big and Tall
- foshon
Re: Foshon's Big and Tall
Took the PG35L apart and cleaned it up. There is no visable damage, so maybe my ire was premature. Here's some pics of the guts.
[img]http://farm8.staticflickr.com/7281/8731484475_cf39417e0f_n.jpg[/img]
Untitled by foshon, on Flickr
[img]http://farm8.staticflickr.com/7287/8731485423_ce7679daa9_n.jpg[/img]
[img]http://farm8.staticflickr.com/7282/8732607280_d85abb3ed8_n.jpg[/img]
[img]http://farm8.staticflickr.com/7281/8732608416_b19c22cf0a_n.jpg[/img]
Purple = sarcasm
that' doesn't look stripped at all from what i can see...
Bet there wasn't much grease in there from the factory. Be sure to pack it good with white grease.
I have several of those and each one came new with barely any grease. Those are good little motors
if you keep them cool with the fan and plenty of grease. Good luck with them.
- foshon
I agree Cambo3d, there was absolutely no signs of anything being worn at all. That leaves me guessing as to why it wouldn't extrude. I think I possibly had my current set to low. I know I could have added more current as there was no sign of even a little heat when it was running. I think this little fella is going to go on junior.
Carl, it had grease in it. just enough to cover the gears, barely. I ended up using a fluoropolymer lube I had sitting around. Did all the research I could stand into if it would react with delrin, couldn't find anything.
Purple = sarcasm
The grease you used should be fine. I agree on the current settings, these motors normally run hot, that's why
you must run the fan. Good luck with it Neil.
- foshon
I wanted a way to purge and clean my nozzle automatically. So I made a thing. It attaches to one of the upright extrusions at bed level (I chose "Z"). It is in two pieces so I can pull the part that interferes with printable area off. The code I use (in theory, haven’t used it yet waiting for hardware) will drop the nozzle into the cup purge 3mm and then wiggle "X" back and forth. I'll probably repeat the process a couple times to be sure.
I foresee the benefit being twofold; one, no more grabbing strings of filament and making a mess, two, the purge takes place about 46mm over and 115mm away from the center of the bed.
It is now here. http://www.thingiverse.com/thing:93820
[img]http://farm9.staticflickr.com/8394/8816550119_6e6a513a61_n.jpg[/img]
[img]http://farm8.staticflickr.com/7396/8827156560_b4c8260e3c_n.jpg[/img]
Edit: added thing
Edit: added thing
Purple = sarcasm
Now that is a great idea! Good job!
Please share the code once you get it working.
Once again, a great idea!
after awhile you probably would still have to clean the brush.. kool idea though
Man that is brilliant!foshon wrote:I wanted a way to purge and clean my nozzle automatically...
be less burned fingertips thats for sure.
Hey Neal, is that brush part of the Dremel collection?
- foshon
Eaglezsoar wrote:Hey Neal, is that brush part of the Dremel collection?
Thanks all.
Sam, it just pulls out of the block, switching it out would be fairly easy, I hope.
Carl, I have no idea. It came in a large multi-piece kit I bought off ebay last year. The shaft is 3.16mm so 1/8th ish. I think that is standard Dremel chuck size.
Purple = sarcasm
What might work well is brass wool used to clean soldering irons. I bet jiggling the nozzle in this would leave it glistening
http://www.newark.com/xytronic/459/sold ... dp/15J6972
I like your brush idea. You could stick the gcode for it in the "prefix" for prints and it would always do that before it starts.
- foshon
Here is the code I put into the start of my prints. I use relative extruder measurements for Slic3r and this is set up for that. It homes, dives the nozzle into the center of the cup, starts heating the noozle and waits for it. Then, it extrudes 5mm wiggles, extrudes 5mm wiggles again, retracts 3mm and puts Y at zero.
G28 ; home all axes
G1 F6000 X3.30 Y115.0 Z45.60
M104 S205
M109
M83 ; use relative distances for extrusion
G1 F5040 E5.0000
G1 F1500 X-5.7
G1 F1500 X13.7
G1 F1500 X-5.7
G1 F1500 X13.7
G1 F1500 X3.3
G1 F5040 E5.000
G1 F1500 X-5.7
G1 F1500 X13.7
G1 F1500 X3.3
G1 F5040 E-3.000
G1 Y0
G92 E0
Purple = sarcasm
I'm curious why your running with relative distance/gcode setup rather than the standard 5D Absolute the majority of us run?
Some unknown advantage? Are you used to it from a previous piece of machinery?
- foshon
Flateric wrote:I'm curious why your running with relative distance/gcode setup rather than the standard 5D Absolute the majority of us run?
Well it started out as frustration when I would purge the nozzle manually only to watch the printer suck the filament out of the hot end at the start of the print. I also can't quite get my head around what happens when filament slips in absolute mode. If it slips on a retract for example, then it tries to rebuild pressure thinking that Xmm of filament isn't there, wouldn't it be prone to grinding the filament. No real reason I suppose, habit and making things like the code above easier.
Purple = sarcasm
- foshon
Purple = sarcasm
- foshon
A note on the micro extruder unit. I have it mounted on junior now, running like a dream. I have been a Wade's/Budda fanboy for so long, I am stunned at the clean lines of the Pg/j-head combo on there now.
Purple = sarcasm
Can you give us a pic of it mounted?foshon wrote:A note on the micro extruder unit. I have it mounted on junior now, running like a dream. I have been a Wade's/Budda fanboy for so long, I am stunned at the clean lines of the Pg/j-head combo on there now.
No problems with the additional weight?
- foshon
It's on my MM+ now. The carriage rides two 8mm steel rods, no weight issues.
Purple = sarcasm
