it comes with all the wood pieces, only. yes it has the top.Eaglezsoar wrote:That TL-1 frame that you purchased, does it come with the top?
I am thinking about purchasing one to get rid of this acrylic, It looks sharp but it cracks if you get things too tight and it is not straight on the top.
I also bought the new arms trick laser has, that should eliminate the Delta Arm Blues permanently.
i just ordered the arms to try out also, =) hopefully it gets rid of the most of the play in the arms, but some of those have play also, so hopefully they picked a good set of ball ends.
I have set of custom arms also coming from an ebay seller in china. Well see how that works out when I get them.
i hate the current rostock arm design, i've sanded 3hours for what i thought was good, only to find out i had to sand another 3hrs for better fit, then i ended up sanding them too much, introduced side play. tried to use washers to take that out, ended up adding more friction..lol...
