Rostock Max Hollow Calibration Pyramid Challenge!
bunkerman
Re: Rostock Max Hollow Calibration Pyramid Challenge!
Postby bunkerman » Tue May 28, 2013 3:32 pm
can some one can show me, what are the bes configuration for rostock max whit rambo board 1.1b and onix?
i tried a lot of things an i make work, but i can print well
i have configured the microstep to 16 an steps per mm to 80 in all 3 axis, steps per mm in extruder is 254, etc
help, it starting to disturb me
bunkerman
Postby bunkerman » Thu May 30, 2013 5:24 pm
Hi, this is my First Functional Print on Rostock Max (using ABS plastic)
and I would like to someone help me with the values ​​of the delta, because when I print something I get it smaller.(i make some modification on that) and the lines are'nt lines, they are a litle bit curby
I modify the EPROM and the configuration file, and here the configuration file
http://www.miditec.com.mx/files/Configuration.h
I'm using the Repetier firmware 0.82.2 on the Rambo board 1.1b and Repetier-Host 0.85b
Help pleace, sorry for the big images
cpunches
Postby cpunches » Sat Jun 29, 2013 10:29 am
Just tried this today to see if my new/hybrid stock hotend + EZ struder would print this. Results are fairly good. 230c ABS
Durandal
Postby Durandal » Sun Jun 30, 2013 1:25 pm
Toner Plastic Neon Orange ABS 1.75mm, 210C directly onto glass at 100C for first layer, 3mm retracts.
texsc98
Postby texsc98 » Fri Jul 05, 2013 8:52 am
My first submission with my new mods... Printed in black 1.75mm ABS!
KISSlicer
230*C
.15mm layers
single perimeter loop
hollow
1mm z-lifts
6/6 suck/prime
9mm wipe
30mm/s
Still having some issues with filament slippage (using EZstruder) as can be seen in the base of the pyramid, but turned out ok overall.
120mm part cooling fan, which I know is insanely large but I wanted to try cooling and it definitely makes a big difference. Long ago I swapped out the original small power supply (because my LEDs were flickering) with a 750W power supply. Resolved the LED flickering, and now I have ample supply for more extruders as well! Long story short I pulled the 120mm fan from the old power supply and used it as a part cooler fan.
Another thing I think helped was the addition of the carbon fiber arms with ball joints, I used to have infill (and other) issues with the original ones.
DIY instructions/videos/hardware links:
Carbon fiber rods w/ ball joints for Rostock MAX ~$40 viewtopic.php?f=36&t=2165
September
Postby September » Fri Jul 05, 2013 11:03 am
First attempt at the pyramid, would appreciate suggestions on how to improve it.
Using Repetier v0.90b Slic3r 0.9.10b, hotbed 100C and hotend 230C. With 1.75mm ABS (210-250C, bilbycnc.com.au).
Fill density - 0.2
Pattern - rectilinear
Top/Bottom Pattern - rectilinear
Extrusion Multiplier - 0.9
Currently no fans.
I think the next attempt I'll drop the hotend by 5 degrees.
thenewguy
Postby thenewguy » Wed Feb 12, 2014 10:24 pm
Black abs
Kiss
.1 layers
ULTIMATE 3D JEDDI
Postby Eaglezsoar » Wed Feb 12, 2014 10:32 pm
That is a good looking pyramid, good job!
MrPTrog
Postby MrPTrog » Fri Feb 14, 2014 4:26 pm
Me: That's a cool DubStep. I really like the drop. But could you turn it down a little?
Son: That's the refrigerator Dad.
And that is why I will never buy HotPoint again!
hax0red
Postby hax0red » Tue Dec 16, 2014 6:05 pm
I was inspired to build a Delta by Xnaron's Pyramid prints compared to my old Printrbot Simple Metal so I pieced together a Kossel Mini and just got her running well enough to post my some of my results. Note that I screwed up bottom layer edges with a scraper removing the part before it cooled.
My build:
Kossel Mini with V rollers vs linear rails, standard Traxxas linkages, real 0.35 Jhead, Azteeg X5 1/32 Microstep but with standard Kysan 1.8* steppers and a heated bed. I have N52 magnets and threaded 10mm balls I plan to add next.
The flat surface is amazingly smooth. Filament is Hatchbox PLA at 190C, Simplify3D slicer with .25 layers, 20mm/second travel speed and 1 120mm fan at 100%(need to go to 2-3 blower style).
ULTIMATE 3D JEDDI
Postby Jimustanguitar » Wed Dec 17, 2014 8:27 am
That's a beautiful pyramid print, congrats! Might be the best one I've seen.
What did you slice it with?
DavidF
Postby DavidF » Wed Dec 17, 2014 10:43 am
Hax0red, that is one sweet print!! Think it is the best I have seen too....
http://www.youtube.com/user/aonemarine
Lost pla castings? see me
ULTIMATE 3D JEDDI
Postby Eaglezsoar » Wed Dec 17, 2014 3:41 pm
I agree with the other two posters, this is one of the best pyramid prints I have seen.
xnaron
Postby xnaron » Wed Dec 17, 2014 3:44 pm
Looks good Hax0red...post some pics of you build in my mag arms thread :)
viewtopic.php?f=54&t=1704
hax0red
Postby hax0red » Thu Dec 18, 2014 3:40 pm
xnaron wrote:Looks good Hax0red...post some pics of you build in my mag arms thread :)
Thanks guys, this print was with no cleanup since the 75mm/sec retract helps reduce the stringing with PLA along with a temp of 190-195C(haven't tried lower yet). I have to admit though xnaron's pyramid printed on his Rostock still has me beat overall IMO but I'm happy to even be in the ballpark this quickly since I just got it assembled and time to start calibration. My biggest concern was that the Delta's would be way too much effort to setup and while they are a little more involved when switching material types and even colors of the same brand I think it's a fair trade off for the chance to have higher quality prints for less money then my PB Metal Simple.
I'll definitely get some pictures posted soon but it still looks a mess as of right now.
hax0red
Postby hax0red » Thu Dec 18, 2014 4:01 pm
Jimustanguitar wrote:That's a beautiful pyramid print, congrats! Might be the best one I've seen.
I used Simplify3D to slice it. Overall a really great slicer and I would recommend it if the price tag was closer to 50-70 USD. Honestly the interface is great and I probably use Simplify3D for 70-75% of my prints and slic3r for the occasions where something wont turn out quite right due to a bug and speaking of bugs there are also a few with Delta configurations that need to be resolved as well before I would consider Simplify3D to be worth the $140 price tag.
So close to being a great product but the price tag really killed the value for me.
lightninjay
Postby lightninjay » Thu Dec 18, 2014 11:52 pm
Hey hax0red, you may want to try out the CraftWare slicer that we've been talking about in The Lounge. It has a lot of configuration similar to S3D... and it's free.
hax0red
Postby hax0red » Fri Dec 19, 2014 5:28 pm
lightninjay wrote:Hey hax0red, you may want to try out the CraftWare slicer that we've been talking about in The Lounge. It has a lot of configuration similar to S3D... and it's free.
Just downloaded it. Features look good so far and the interface is nice but not as intuitive yet as Simplify3D. Will report back after a few prints, thanks lightninjay!
jram
Postby jram » Sun Dec 21, 2014 5:18 pm
failed rocket
Thought I'd give this a shot. I'm somewhat happy with the outer perimeters but it's a bit blobby on the inner area.It's printed at 198, 60c bed-.20 layer height and 4.5mm retracts.It seems no matter what I do, I can't get pointy areas to work. I have uploaded another failed rocket pic, I stopped this mid print because of the blobs forming at the points.
xnaron
Postby xnaron » Sun Dec 21, 2014 5:23 pm
Do you have fans cooling your print?
jram
Postby jram » Sun Dec 21, 2014 5:42 pm
Hi Xnaron. I have one fan though it doesn't seem to be blowing much. It's larger one that I put on, someone on the forum recommended this. It seems to be spinning really slowly. I have a few smaller fans sitting around with printed shrouds. Can I just tap into the existing wiring to add more?
noishi
Postby noishi » Mon Dec 22, 2014 9:55 pm
Does anyone have a good resource they don't mind sharing on trouble shooting your prints? I'm trying to figure out how to improve my prints but am finding help hard to find. My main issue is the inner pyramid, and cleaning that up. I am initially thinking it is due to retraction, any tips?
ABS 1.75mm
230C hot end
100C bed
6mm retraction
.2 infill (triangles)
40mm/s print speed
.3mm z lift
.25mm layer height
hax0red
Postby hax0red » Wed Dec 31, 2014 8:53 pm
noishi wrote:Does anyone have a good resource they don't mind sharing on trouble shooting your prints? I'm trying to figure out how to improve my prints but am finding help hard to find. My main issue is the inner pyramid, and cleaning that up. I am initially thinking it is due to retraction, any tips?
ABS 1.75mm
230C hot end
100C bed
6mm retraction
40mm/s print speed
.3mm z lift
.25mm layer height
I would try 20mm/s, no retract(adds possibility for move errors to accumulation) and be sure to use a really good fan on the pyramids since each layers time is pretty short. My prints with ABS didn't turn out too much better but I know the settings I listed made a small difference.
dunginhawk
Postby dunginhawk » Thu Jan 01, 2015 2:50 pm
Hax0red.. how do you like the hatchbox PLA? i have a bunch of the PLA and a bunch of the ABS.. its honestly all ive bought so far (new to this). Seems like you got good results. Just curious as to how it compares to some of the others.. Its cheap, thats what i like.
dunginhawk
Postby dunginhawk » Thu Jan 01, 2015 5:07 pm
so here is mine... im actually really dissapointed... the close up does make it look worse, but i had a little stringing, and the blob on top...
the outside edges look REALLY good, but the inside are a little off.
wondering where to touch up... i think i need to work on the retraction piece of things.
edit : it did not peel up and deform the bottom right corner, its just sitting awkwardly on a piece of paper :)
Who is online
