Watch Winder (could use some expertise on code)
wepollock
Post by wepollock » Sat Nov 18, 2017 3:30 pm
https://www.thingiverse.com/thing:2654679
I have some issues with the Rotary Encoder code.. If someone that is knowledgeable on that subject could take a look at the INO file on Thingiverse it would be appreciated.
enggmaug
Re: Watch Winder (could use some expertise on code)
Post by enggmaug » Sun Nov 19, 2017 3:16 pm
What do you mean "some issues" ?
I don't want to open your code if I don't know what I'm looking for...
Did you deal with rebounds ? some rotary encoders bounce alot. Last time I used one, I had to add a low pass filter (capapacitor and resistor) to kill them rebounds before entering the arduino.
dc42
Post by dc42 » Tue Nov 21, 2017 4:35 pm
Rotary encoder bounce doesn't matter if the driver software is correctly written and only one contact bounces at a time. When I first connected a rotary encoder to an Arduino about 4 years ago, all the existing driver code I found was rubbish, so I wrote my own. If you want to try it, it's at https://github.com/dc42/arduino/tree/master/Libraries.
