Head, not from a max, but it's spiritual successor.
bot
Post by bot » Mon Aug 29, 2016 6:12 pm
Printed another head scan; holy fuck. Pardon my french.
more: http://imgur.com/a/TV74Z
Not on a rostock max, but was my next printer and based essentially off the max.
*not actually a robot
KAS
ULTIMATE 3D JEDDI
Re: Head, not from a max, but it's spiritual successor.
Post by KAS » Mon Aug 29, 2016 6:52 pm
Damn, Bot. That's crazy!
DeltaCon
Post by DeltaCon » Tue Aug 30, 2016 5:36 am
Holy sh!t!
I can imagine it is rather creepy to see your own deathface like that! ;-)
Impressive resolution!
Interesting custom built also...
The direction of the arms is skew to the position of the front towers...?
Tincho85
Post by Tincho85 » Tue Aug 30, 2016 5:58 am
That's one impressive print, but I won't lie, I have mixed emotions right know.
Very happy for you and what you achieved with your machine buy kinda jealous :P
Thanks for sharing bot.
PS: that black label... man, made me hate you more hahaha
Martín S.
jmpreuss
Post by jmpreuss » Tue Aug 30, 2016 9:23 am
I'm impressed with the print, more impressed with the scan. How did you get such an accurate model?
critical_limit
Post by critical_limit » Tue Aug 30, 2016 9:40 am
please share more informations about Material, layerheight, etc.
impressive print mate!
bot
Post by bot » Tue Aug 30, 2016 10:39 am
Thanks everyone.
I thought I had print info in the album but here goes:
80 micron layer height, filaments.ca PLA at "210" through an e3d v6 400 micron nozzle, slow speed 50mm/s and insanely low jerk of 480mm/min. 3 perimeters, no infill, some top and bottom layers close to the perimeter thickness. Slides with simplify3d. Oh yeah, 94 hour print time!!!!
The slicing took ages. Writing the 1gb gcode file after slicing tool even longer. I needed to buy a crazy gaming pc with 64gb ram to slice this haha.
The model was made by a professional scanning company, using photogrammetry. They have a crazy truck full of like 100 cameras. I believe they extract the pore data from the images and bake it into the model manually. Something like 20 million polygons. It's not me, it's my brother.
bot
Post by bot » Tue Aug 30, 2016 10:43 am
DeltaCon wrote:Holy sh!t!
I can't see what you mean. I did adjust the bed to be more try to the towers, if that's what you mean? I'm sure the geometry isn't perfect either. Or possibly the photo is icing a weird angle.
DeltaCon
Post by DeltaCon » Tue Aug 30, 2016 2:43 pm
bot wrote:
DeltaCon wrote:The direction of the arms is skew to the position of the front towers...?
The attachment is a snippet of a picture from your Imgur pages. I can see clearly that the sides of the tower are square to the front and not rotated 60 degrees to point to the center of the printbed. However I took a closer look at your Z tower and now noticed that you are using linear rails and there are no cheapskates running up and down the extrusions. But even then I think it is a hell of a calibration job to get the rotation of the linear rail tuned, isn't it? But clearly done with great succes! ;-)
bot
Post by bot » Tue Aug 30, 2016 3:27 pm
Ah, I see what you mean. I used these http://us.misumi-ec.com/vona2/detail/11 ... 733%3A%3Ag three of each for a tower, and so in the middle on the front face is another normal extrusion that the rail is bolted to. It works okay, but it's not an absolutely ideal solution. I have other ideas for if I make another one, basically tying the three separate columns together. I have an album of the printer build here: https://imgur.com/a/2A1fF the first pic shows the angle extrusion. The middle one, with the rail attached, is shorter than the other two -- something I wouldn't repeat a second time.
bot
Post by bot » Tue Aug 30, 2016 3:29 pm
Actually, some more pics of everything if you look at my imgur profile: https://bottt.imgur.com/
ULTIMATE 3D JEDDI
Post by Eaglezsoar » Wed Aug 31, 2016 12:56 am
Thank you for the pictures. Great job!
