False line keeps printing??
Potatohead908
Post by Potatohead908 » Fri Aug 14, 2015 9:48 pm
Why am I getting this line thru my print? It just started happening. :evil:
teoman
ULTIMATE 3D JEDDI
Re: False line keeps printing??
Post by teoman » Sat Aug 15, 2015 6:46 am
Do you see it in the software?
Mind posting the g-code for that print?
Potatohead908
Post by Potatohead908 » Sat Aug 15, 2015 10:22 am
Nope. It only shows on the print.
I downloaded Slic3r and just print via SD card. Same STL's and no false line.
ULTIMATE 3D JEDDI
Post by Eaglezsoar » Sat Aug 15, 2015 2:53 pm
Potatohead908 wrote:Nope. It only shows on the print.
If I understand this correctly, your old slicer is what was causing the problem?
bot
Post by bot » Sun Aug 16, 2015 7:26 pm
I've seen this featured called "prime" something... It's inserting start g-code to print a prime line before the print starts. Unfortunately, the coordinates it chooses to do it are right in the way for you.
*not actually a robot
Potatohead908
Post by Potatohead908 » Mon Aug 17, 2015 12:44 pm
Oddly enough it does this midway through the first layer printing. I have caught it and stopped it each time so I don't know if it would just continue on with the print.
BenTheRighteous
Post by BenTheRighteous » Mon Aug 17, 2015 12:45 pm
What slicer was giving you the problem?
bot
Post by bot » Mon Aug 17, 2015 12:46 pm
That's REALLY weird then... it looks very intentional haha. Is it some kind of tool chance gcode that is mistakenly being inserted?
Potatohead908
Post by Potatohead908 » Mon Aug 17, 2015 12:50 pm
BenTheRighteous wrote:What slicer was giving you the problem?
I think it may have started in Matterslice however I changed to Slic3r within MC about the time it started. I can't remember which one it started in but it does it in both Matterslice and Slic3r within MC.
Last edited by Potatohead908 on Mon Aug 17, 2015 1:00 pm, edited 2 times in total.
Potatohead908
Post by Potatohead908 » Mon Aug 17, 2015 12:52 pm
I don't know. Moving to an external copy of Slic3r and printing from and SD card has eliminated the issue.
ULTIMATE 3D JEDDI
Post by Eaglezsoar » Tue Aug 18, 2015 5:59 am
Great that you got it to work.
