y axis sticking
burro breath
y axis sticking
Post by burro breath » Mon Sep 17, 2012 12:31 pm
so my printer was working well and then i put the heated bead on and now the y axis sticks at some points in the print and then mis prints because the stepps are off. i totally cleaned the bearing and slide rods and readjusted the belt tension and everything seams right. i test the motor with no belt and it does not skip steps. i also have the guide rods parrellel within .005". with the belt off the table moves buttery smooth by hand...what is the problem? im using the h 1.1 kit.
michaellatif
Re: y axis sticking
Post by michaellatif » Mon Sep 17, 2012 1:09 pm
What motor drivers are you using? RAMPS or parallel port board?
Mike Latif
H-1 #3
burro breath
Re: y axis sticking
Post by burro breath » Mon Sep 17, 2012 2:24 pm
I am using the latest version of ramps
stienman
Re: y axis sticking
Post by stienman » Mon Sep 17, 2012 2:31 pm
Have you adjusted the current drivers for the motors on the ramps board? They are adjustable, and it's possible that they are set low enough on yours that adding the extra mass of the heated bed causes it to lose steps on quick reverses.
Also, try slowing the whole thing down and see if you still skip steps. If slowing down fixes the problem, it's probably a mass/motor current issue.
burro breath
Re: y axis sticking
Post by burro breath » Tue Sep 18, 2012 3:48 pm
i increased the amps going to the y motor and it barely helped im still having trouble with the y axis sticking. i am going to have to strip the whole axis and try and figure it out this weekend
burro breath
Re: y axis sticking
Post by burro breath » Wed Sep 19, 2012 3:44 pm
does anyone have any clue as to what my problem could be
xojins
Re: y axis sticking
Post by xojins » Wed Sep 19, 2012 4:08 pm
im having a similar issue. I decided to take apart my printer and re-align everything.
I did come across one problem. My aluminum bushings for the front and back bearing were too long. I used a wet grinder and reduced the length to 0.31". I am still reassembling, but hoping that helps.
tom10122
Re: y axis sticking
Post by tom10122 » Wed Sep 19, 2012 4:14 pm
y-axis bearing assemblies aren't hitting the sides are they? I had that problem
xojins
Re: y axis sticking
Post by xojins » Wed Sep 19, 2012 4:17 pm
tom10122 wrote:y-axis bearing assemblies aren't hitting the sides are they? I had that problem
how did you fix that?
tom10122
Re: y axis sticking
Post by tom10122 » Wed Sep 19, 2012 4:43 pm
Well, I didn't notice it til I replaced the plastic bed with some plexiglass, I drilled a new set of holes closer together and moved the rails closer in so they no longer touch
