I wanted to do a routine calibration to iron out some of the kinks in my models. So i fire up the computer and pull up the trusty assembly guide and scroll down to the calibration portion. Let's do this.
So I run scripts 1, 2, 3, 4 just like it's listed in the calibration manual. I've been adjusting the horizontal radius in increments of .2. I'm trying to get it as close to perfect as possible. I get to a state where I'm pretty happy with how everything is working. I run script 1, 2, 3, 4 and the paper seems to have about the same clearance under each one. NICE!
but wait...
Then I run an alignment script I had seen someone on here post:
G28
G1 Z0.2 F15000
G4 S1
G1 X-77.94 Y-45 F2000
G4 S2
G1 X0 Y0
G1 X77.94 Y-45
G4 S2
G1 X0 Y0
G1 Y90
G4 S2
G1 X0 Y0
The idea is that you watch the hot end head that is .2mm above your print surface and look for changes in height. Makes sense to me. So I run it and here is the part that makes me
. When it lowers down to 0,0,0.2 everything is looking good. But then as it moves to each tower and back, first to X, then to Y, and then to Z, the hot end grips the paper more and more. Basically it seems like the more it moves horizontally the more it lowers the hot end. At the end the Z height is still supposed to be at 0.2, yet it is gripping the paper like crazy.
Has anyone experience this behavior?? It is incredibly frustrating!!
