Two opposite sides of a thin walled print:
[img]http://i.imgur.com/ZrxJPnG.jpg?1[/img]
[img]http://i.imgur.com/FWww2qy.jpg?1[/img]
This is the location of the nozzle leaving one side and moving over the opposite. It initially left a spider web of ultra thin strands between the two.
Thoughts on this?
Rostock Max. Repetier .80 firmware (does that seem right?). Glowing ABS filament. 230 extruder temp. 60 bed temp.
Spiderweb thin ABS as nozzle leaves
McSlappy
Re: Spiderweb thin ABS as nozzle leaves
sliced with which program?
McSlappy
Bah I knew I was forgetting something. Slic3r.
I need to come up with my default stats to paste into my posts...
- foshon
Have you tried increasing retraction length or speed?
Purple = sarcasm
McSlappy
That's a good idea. I might up that.
it looks like that is also the start location of the loops? try randomizing the loop start location if so
McSlappy
Retract helped a little, there are some blobs on the location still, I'll do the randomize now.
McSlappy
I'm continuing this thread here since it seemed more fitting to a run of failed prints
http://forum.seemecnc.com/viewtopic.php?f=62&t=3944
