Rostock V4 - SE300 - Barrel fan not working.
Michail1
Post by Michail1 » Sun Sep 29, 2019 8:24 pm
I have a V4 and V3.2
The V4 is less than a month old. Just ran into a problem in that the filament would stick in the barrel after a few MM of feed. Nearly impossible to pull out. So, it appears the filament is melting in the barrel. So, I discovered the barrel fan wasn't spinning.
So, suggestions other than simply testing the fan?
Re: Rostock V4 - SE300 - Barrel fan not working.
Post by Mac The Knife » Mon Sep 30, 2019 8:21 am
Test the connections for the fan,,,,,,,,,
Post by geneb » Mon Sep 30, 2019 8:27 am
Make sure the fan body isn't compressed against the fan blades.
Michail1
Post by Michail1 » Mon Sep 30, 2019 2:43 pm
The fan freely rotates by finger.
I pulled and connected to a 12v supply and confirm that the fan works.
Will re-assemble when I get home to see if that was enough. Assuming the fan will not spin at that point though.
Michail1
Post by Michail1 » Fri Oct 04, 2019 7:41 pm
I have confirmed that the purple wire is correctly connected to the Duet and is pin 1 on the 10pin connector.
I confirmed there is continuity with a meter.
I confirmed the 10pin socket (pin1) has continuity to the fan socket and that the other pin of the fan socket goes to ground.
I have uploaded several pictures to imgur at the following link.
https://imgur.com/a/3SVYUFU
Also, there is no bad solder joints or burn marks on the head.
It appears the only thing left is the Duet board.
Post by geneb » Sat Oct 05, 2019 8:38 am
Have you contacted support about this yet? If not, you need to.
Post by geneb » Sat Oct 05, 2019 8:39 am
Also, the cold-section fan will only be running when the hot end temperature is > 60C or so. You should also check the fan output with a multi-meter after the hot end is at temperature.
Michail1
Post by Michail1 » Sat Oct 05, 2019 1:04 pm
After my initial post and realizing it wasn't a simple problem, I put in a trouble ticket, but decided to continue with this thread so that others may follow to resolution in case they run into the same issue at some point in the future.
They responded with performing the initial diags that I explained in my third post in the thread, and am waiting on a response now.
You are close regarding the temperature and I took that into consideration.
Note: M106 P2 T50 S0.7 H1 ; Heat sink fan
It is 50c when it should kick in to prevent the heat soak I am getting. It doesn't.
Basically, it appears that TR1 (transistor for the fan) may be bad on the Duet. If I plug in the fan to the next port (always on), it works.
I added photos to the original Imgur.com link to show the top and bottom of the circuit board to show that nothing is visibly burned. Didn't let the smoke out - at least it passes the smell/visual test.
Also note.... It worked correctly for about a week and magically stopped working. I still believe the Duet board simply went bad.
Michail1
Re: Rostock V4 - SE300 - Barrel fan not working. (Resolved)
Post by Michail1 » Thu Nov 07, 2019 5:44 am
Turns out the Duet Board was bad. Replaced under warranty... All good now.
Post by geneb » Thu Nov 07, 2019 8:42 am
\o/
