Error compiling for board RAMBo
MrPTrog
Post by MrPTrog » Mon Sep 10, 2018 10:45 am
Downloaded the latest firmware
Downloaded Arduino 1.8.6
Ran eeprom_clear (That worked great, now I have no firmware)
Every time I try to compile I get this
Arduino: 1.8.6 (Windows 10), Board: "RAMBo"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\USER\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\USER\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\USER\Documents\Arduino\libraries -fqbn=rambo:avr:rambo -vid-pid=0X27B1_0X0001 -ide-version=10806 -build-path C:\Users\USER\AppData\Local\Temp\arduino_build_199297 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\USER\Downloads\Firmware-master (12-04-2017)\Firmware-master\Repetier Firmware\Repetier\Repetier.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\USER\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\USER\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\USER\Documents\Arduino\libraries -fqbn=rambo:avr:rambo -vid-pid=0X27B1_0X0001 -ide-version=10806 -build-path C:\Users\USER\AppData\Local\Temp\arduino_build_199297 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\USER\Downloads\Firmware-master (12-04-2017)\Firmware-master\Repetier Firmware\Repetier\Repetier.ino
Using board 'rambo' from platform in folder: C:\Users\USER\AppData\Local\Arduino15\packages\rambo\hardware\avr\1.0.1
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Repetier.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Repetier.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Repetier.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Commands.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Communication.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Eeprom.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Extruder.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\HAL.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Printer.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SDCard.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SdFat.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\gcode.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\motion.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\ui.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src\\SPI.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src\\utility\\twi.c" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Repetier.ino.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Communication.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Communication.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Commands.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Commands.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Extruder.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Extruder.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SDCard.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SDCard.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Eeprom.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Eeprom.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SdFat.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SdFat.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\motion.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\motion.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\ui.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\ui.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Repetier.ino.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Repetier.ino.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\gcode.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\gcode.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\HAL.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\HAL.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Printer.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Printer.cpp.o"
Compiling libraries...
Compiling library "SPI"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src\\SPI.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\libraries\\SPI\\SPI.cpp.o"
Compiling library "Wire"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src\\Wire.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\libraries\\Wire\\Wire.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src\\utility\\twi.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\libraries\\Wire\\utility\\twi.c.o"
Compiling core...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_pulse.S.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_digital.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_analog.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\hooks.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\hooks.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_pulse.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\WInterrupts.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_shift.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\main.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\main.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial0.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\Print.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\Print.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial1.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\Stream.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\CDC.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial2.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\USBCore.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\new.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\new.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\Tone.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial3.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\WMath.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\IPAddress.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\PluggableUSB.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\WString.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\WString.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\abi.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\abi.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\CDC.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial0.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial1.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial2.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial3.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\IPAddress.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\PluggableUSB.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\Print.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\Stream.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\Tone.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\USBCore.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\WInterrupts.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\WMath.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\WString.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\abi.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\hooks.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\main.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\new.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_analog.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_digital.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_pulse.S.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_pulse.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_shift.c.o"
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560 -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297/Repetier.ino.elf" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Commands.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Communication.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Eeprom.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Extruder.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\HAL.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Printer.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Repetier.ino.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SDCard.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SdFat.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\gcode.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\motion.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\ui.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297/core\\core.a" "-LC:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297" -lm
C:\Users\USER\AppData\Local\Temp\ccu2dGhq.ltrans6.ltrans.o: In function `__vector_17':
C:\Users\USER\AppData\Local\Temp\arduino_build_199297\sketch/HAL.cpp:677: undefined reference to `stepperWait'
C:\Users\USER\AppData\Local\Temp\ccu2dGhq.ltrans6.ltrans.o:C:\Users\USER\AppData\Local\Temp\arduino_build_199297\sketch/HAL.cpp:677: more undefined references to `stepperWait' follow
collect2.exe: error: ld returned 1 exit status
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
exit status 1
Error compiling for board RAMBo.
I go back to Arduino 1.8.5 and it compiles but wont upload.
Arduino: 1.8.5 (Windows 10), Board: "RAMBo"
C:\arduino-1.8.5\arduino-builder -dump-prefs -logger=machine -hardware C:\arduino-1.8.5\hardware -hardware C:\Users\USER\AppData\Local\Arduino15\packages -tools C:\arduino-1.8.5\tools-builder -tools C:\arduino-1.8.5\hardware\tools\avr -tools C:\Users\USER\AppData\Local\Arduino15\packages -built-in-libraries C:\arduino-1.8.5\libraries -libraries C:\Users\USER\Documents\Arduino\libraries -fqbn=rambo:avr:rambo -vid-pid=0X27B1_0X0001 -ide-version=10805 -build-path C:\Users\USER\AppData\Local\Temp\arduino_build_446917 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\arduino-1.8.5\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\arduino-1.8.5\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\arduino-1.8.5\hardware\tools\avr -verbose C:\Users\USER\Downloads\Firmware-master (12-04-2017)\Firmware-master\Repetier Firmware\Repetier\Repetier.ino
C:\arduino-1.8.5\arduino-builder -compile -logger=machine -hardware C:\arduino-1.8.5\hardware -hardware C:\Users\USER\AppData\Local\Arduino15\packages -tools C:\arduino-1.8.5\tools-builder -tools C:\arduino-1.8.5\hardware\tools\avr -tools C:\Users\USER\AppData\Local\Arduino15\packages -built-in-libraries C:\arduino-1.8.5\libraries -libraries C:\Users\USER\Documents\Arduino\libraries -fqbn=rambo:avr:rambo -vid-pid=0X27B1_0X0001 -ide-version=10805 -build-path C:\Users\USER\AppData\Local\Temp\arduino_build_446917 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\arduino-1.8.5\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\arduino-1.8.5\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\arduino-1.8.5\hardware\tools\avr -verbose C:\Users\USER\Downloads\Firmware-master (12-04-2017)\Firmware-master\Repetier Firmware\Repetier\Repetier.ino
Using core 'arduino' from platform in folder: C:\arduino-1.8.5\hardware\arduino\avr
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.8.5\hardware\arduino\avr\cores\arduino" "-IC:\Users\USER\AppData\Local\Arduino15\packages\rambo\hardware\avr\1.0.1\variants\rambo" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Repetier.ino.cpp" -o "nul"
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.8.5\hardware\arduino\avr\cores\arduino" "-IC:\Users\USER\AppData\Local\Arduino15\packages\rambo\hardware\avr\1.0.1\variants\rambo" "-IC:\arduino-1.8.5\hardware\arduino\avr\libraries\SPI\src" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Repetier.ino.cpp" -o "nul"
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.8.5\hardware\arduino\avr\cores\arduino" "-IC:\Users\USER\AppData\Local\Arduino15\packages\rambo\hardware\avr\1.0.1\variants\rambo" "-IC:\arduino-1.8.5\hardware\arduino\avr\libraries\SPI\src" "-IC:\arduino-1.8.5\hardware\arduino\avr\libraries\Wire\src" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Repetier.ino.cpp" -o "nul"
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Commands.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Communication.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Eeprom.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Extruder.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\HAL.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Printer.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\SDCard.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\SdFat.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\gcode.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\motion.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\ui.cpp
Using cached library dependencies for file: C:\arduino-1.8.5\hardware\arduino\avr\libraries\SPI\src\SPI.cpp
Using cached library dependencies for file: C:\arduino-1.8.5\hardware\arduino\avr\libraries\Wire\src\Wire.cpp
Using cached library dependencies for file: C:\arduino-1.8.5\hardware\arduino\avr\libraries\Wire\src\utility\twi.c
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.8.5\hardware\arduino\avr\cores\arduino" "-IC:\Users\USER\AppData\Local\Arduino15\packages\rambo\hardware\avr\1.0.1\variants\rambo" "-IC:\arduino-1.8.5\hardware\arduino\avr\libraries\SPI\src" "-IC:\arduino-1.8.5\hardware\arduino\avr\libraries\Wire\src" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Repetier.ino.cpp" -o "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\arduino-1.8.5\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Commands.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Communication.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Eeprom.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Extruder.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\HAL.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Printer.cpp.o
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.8.5\hardware\arduino\avr\cores\arduino" "-IC:\Users\USER\AppData\Local\Arduino15\packages\rambo\hardware\avr\1.0.1\variants\rambo" "-IC:\arduino-1.8.5\hardware\arduino\avr\libraries\SPI\src" "-IC:\arduino-1.8.5\hardware\arduino\avr\libraries\Wire\src" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Repetier.ino.cpp" -o "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Repetier.ino.cpp.o"
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\SDCard.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\SdFat.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\gcode.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\motion.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\ui.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\libraries\SPI\SPI.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\libraries\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\libraries\Wire\utility\twi.c.o
Compiling core...
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\wiring_pulse.S.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\WInterrupts.c.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\hooks.c.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\wiring.c.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\wiring_analog.c.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\wiring_digital.c.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\wiring_pulse.c.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\wiring_shift.c.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\CDC.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\HardwareSerial.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\HardwareSerial0.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\HardwareSerial1.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\HardwareSerial2.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\HardwareSerial3.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\IPAddress.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\PluggableUSB.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\Print.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\Stream.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\Tone.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\USBCore.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\WMath.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\WString.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\abi.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\main.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\new.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\core.a
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560  -o "C:\Users\USER\AppData\Local\Temp\arduino_build_446917/Repetier.ino.elf" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Commands.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Communication.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Eeprom.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Extruder.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\HAL.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Printer.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Repetier.ino.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\SDCard.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\SdFat.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\gcode.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\motion.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\ui.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\libraries\SPI\SPI.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\libraries\Wire\Wire.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\libraries\Wire\utility\twi.c.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917/core\core.a" "-LC:\Users\USER\AppData\Local\Temp\arduino_build_446917" -lm
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Users\USER\AppData\Local\Temp\arduino_build_446917/Repetier.ino.elf" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917/Repetier.ino.eep"
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\USER\AppData\Local\Temp\arduino_build_446917/Repetier.ino.elf" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917/Repetier.ino.hex"
Using library SPI at version 1.0 in folder: C:\arduino-1.8.5\hardware\arduino\avr\libraries\SPI
Using library Wire at version 1.0 in folder: C:\arduino-1.8.5\hardware\arduino\avr\libraries\Wire
Sketch uses 135182 bytes (52%) of program storage space. Maximum is 258048 bytes.
Global variables use 7309 bytes of dynamic memory.
An error occurred while uploading the sketch
Both of those errors are after repeated trys
Fortunately Arduino 1.8.5 will compile and upload FW version 0.92.2 date 20161014
So I am back where I started.
Does anyone know what version of Arduino will compile and upload The latest version of firmware?
Me: That's a cool DubStep. I really like the drop. But could you turn it down a little?
Son: That's the refrigerator Dad.
And that is why I will never buy HotPoint again!
MrPTrog
Re: Error compiling for board RAMBo
Post by MrPTrog » Mon Sep 10, 2018 4:02 pm
Did a board info on Arduino 1.8.5 and got
BN: RAMBo
VID: 27B1
PID: 0001
SN: 64036363638351D0D1C0
I Dont know if that is useful info or not.
ULTIMATE 3D JEDDI
Post by geneb » Tue Sep 11, 2018 10:12 am
You need to use the 1.6.0 version of the Arduino IDE.
MrPTrog
Post by MrPTrog » Tue Sep 11, 2018 11:57 am
Thank you Gene, That did it!
ULTIMATE 3D JEDDI
Post by geneb » Tue Sep 11, 2018 5:07 pm
\o/
Soulemaan
Post by Soulemaan » Mon Oct 15, 2018 12:02 pm
I learned this the hard way after many frustrating hours!
TruckerGeek
Post by TruckerGeek » Sun Oct 28, 2018 5:03 pm
Fortunately I searched for the error before I spent too much time on the issue and found this post. I am installing 1.6.0 now.
It did bring it back to life!!
SeeMeCNC Rostock MAX V2 (w/HE280), Raspberry PIs and Arduinos
A licensed truck driver (CDL), former US Air Force Firefighter and high end computer geek
tupper
Post by tupper » Fri Jan 25, 2019 9:07 am
Just change one line in HAL.cpp from:
long stepperWait = 0;
to
long __attribute__((used)) stepperWait = 0;
fixes the linker error under Arduino 1.8.7 and allows the old Repetier program to compile and run.
See https://forum.repetier.com/discussion/5 ... d-sanguino .
Should this commit be pushed (reverse compatibility untested)?
ULTIMATE 3D JEDDI
Post by geneb » Sat Jan 26, 2019 9:41 am
The issue isn't compiler capability, it's one of code generation. The firmware consumes nearly all the memory resources on the RAMBo. There was some change made in post 1.6.0 compilers that causes the resulting binary to randomly crash.
