Delta Calibration Wizard Error!
got robot? FTC 5037
Post by got robot? FTC 5037 » Wed Mar 28, 2018 11:32 am
I'm having trouble with the Delta Calibration Wizard on the Seemecnc website. I plug in all the values and when I click to calculate the new values I get a message stating: Error! At least one probe point is not reachable. "Please correct your delta radius, diagonal rod length, or probe coordinates."
I've tried plugging in the values three times and I'm fairly confident that they are the correct values. I get the error at home on my PC laptop as well as my Mac at work.
Attached is a PDF of the Delta Calibration Wizard with my values. I have also attached and export from my eeprom settings and the print log with the probed offset values.
The printer is a stock 2015 Orion that was just recently upgraded with the new ball arms kit, injection molded carriages, and the HE280 hot end. The firmware has been updated and the Auto Calibration sequence is working.
Hopefully, it's something simple. But at the moment I'm stumped.
Delta Calibration Wizard – SeeMeCNC.pdf
Screen print of the Delta Calibration Wizard
(155.82 KiB) Downloaded 12 times
print_log from Delta Calibration Wizard.txt
Print log of the probed offsets
(34.56 KiB) Downloaded 3 times
eeprom_settings.ini
Eeprom settings
(2.07 KiB) Downloaded 4 times
got robot? FTC 5037
Re: Delta Calibration Wizard Error!
Post by got robot? FTC 5037 » Wed Mar 28, 2018 1:05 pm
SOLVED: Turns out I should be using the numbers immediately after the colon and NOT in the numbers inside the brackets.
<-PROBE-ZOFFSET:-0.01 [5.547]
Thanks for setting me straight Gene!
ULTIMATE 3D JEDDI
Post by geneb » Thu Mar 29, 2018 8:39 am
\o/ :D
