Weak first layer extrusion, jams mid print.
buggy
Postby buggy » Fri Feb 02, 2018 6:41 pm
After completing my upgrade to the duet wifi, fsr setup and titan extruder i still havent managed a successful print. Calibrated esteps, auto calibration and bed mesh compensation.
During the upgrade i followed mhackneys guide on his sublimelayers blog, used the firmware files he supplied but hopefully changed them to fit my max v2.
Now to my current issue. When i go to print my first layer seems to be under extruding. Ive adjusted the zprobe offset with no change to the first layer extrusion. If i turn the extrusion multiplier up to 120% it looks around what i would expect. After the first 2 layers i change it back to 100% and let the print continue. After a few layers it seems like my hotend jams.
Does anyone have any ideas of what the problem could be? Im new to the reprap firmware so i could be missing something. I can post my config.g and bed.g if that helps.
Dan
Re: Weak first layer extrusion, jams mid print.
Postby geneb » Sat Feb 03, 2018 10:00 am
buggy, what model are you printing? What hot end are you using? What slicer?
Do you have the tension on the Titan properly adjusted?
tnx.
buggy
Postby buggy » Sat Feb 03, 2018 10:39 am
Thanks for the reply, also a fellow washingtonian (everett)! I think i might have solved the weak first layer extrusion problem, i guess i didnt use a drastic enough z offset. Originally i was using around -.07 when it turns out i needed closer to -.17. It still seems like im getting a lot of back pressure in the nozzle which translates to the extruder. Im trying to print just a universal duet mounting board, im using a e3d v6 and i swapped back to my ez-extruder to see if that would help with the issue.
I was doing more reading trying to solve my issues and realized i may have missed a step during the calibration process. I think i still need to set up my z offset for each of the probing locations.
Also im using bed mesh compensation with auto calibration but i believe i need to include the gcode to have it taper off after a certain height which might solve the issue of my extruder jamming after a few layers.
Who is online
Users browsing this forum: No registered users and 3 guests
