G28 problem- please help!
cambo3d
Re: G28 problem- please help!
Post by cambo3d »
chbeckdb9 wrote:I checked the wiring again, and pulled each 4 pin motor connector out, inspected it and plugged it back in. All had a nice fit. Each has the wire order just like in the build manual, showing yellow, blue, red, green. I attached a photo showing the connector. I am using the repetier available on seemecnc. I have not altered the motor current, I have only done exactly what it says in the manual. Of course this could still be the problem.
yes those pins are improperly crimped, not allowing your pins to fully seat. they need to go all the way in.
lordbinky
Post by lordbinky »
My dog came and threw up under my desk, so that took me longer than I thought.... you'd figure he wouldn't eat stuffing from toys if it did that but.....
Anyways.. Here's pictures of my connector. It clicks into place when done right, you should have to press the little tab down to pull the back out, and you will not see the base of the connector
edit: Just to give another example apparently lol...
chbeckdb9
Post by chbeckdb9 »
Thanks! that got it working.
I really appreciate the quick responses, I can't believe I overlooked something so simple.
jmick
Post by jmick »
HT-225D Full Cycle Ratchet Crimping Tool with interchangeable die set HT-225D
Misc.
Sold by Coolerguys
Facebook Twitter Pinterest
$23.00
That's essentially the same tool I have, but for a hell of a lot less than what I paid for it. :) I wouldn't mind finding a source for new dies...
The HT-225D is available from Amazon for $23 with Prime Shipping. Great price if you are a Prime shipping member.
