I think your going to have to flip some wires around in thier connectors, I will have to look at things when I get home to see if there is some other way. Weird!! Setting the direction t/f should only change the motors rotation.
But your saying you have to change directions to get it to go down, then change it again to go home??
Home reverse from end stops. Please help!
Re: Home reverse from end stops. Please help!
Lost pla castings? see me
Interesting... That was exactly what was happening but now it seems to have corrected itself after I saved and reloaded the firmware... Axes are inverted as above, yet problem is no longer presenting itself? Oh well, I guess problem solved!DavidF wrote:I think your going to have to flip some wires around in thier connectors, I will have to look at things when I get home to see if there is some other way. Weird!! Setting the direction t/f should only change the motors rotation.
The above is how things are set currently. I guess it doesn't matter if it's working lol ^^// Inverting axis direction
#define INVERT_X_DIR true
#define INVERT_Y_DIR false
#define INVERT_Z_DIR true
Anyway, I guess someone can close this issue now. The firmware may have been glitching because of the previous issue. I had a feeling it was all related... If I have the issue re-crop I'll mention it here. Well, after homing z-axis appears as 353.95, so all that should remain is to recalibrate the hotend and bed, and then calibrate the axes
Thanks again m8
Oh, and thanks to everyone that tried to assist
no problem, glad to have helped. Funny on the ride home I was going to suggest re uploading the firmware. Maybe im getting better at my diagnosis....
haha Yeah, I thought perhaps it wouldn't hurt to reupload again. I've uploaded the firmware so many times I've lost count. It's funny how simple the solution was yet so frustrating to solve. Human error on my part, all traced back to that damn crossed motor wire lol ^^DavidF wrote:no problem, glad to have helped. Funny on the ride home I was going to suggest re uploading the firmware. Maybe im getting better at my diagnosis....
Indeed, good diagnosis doctor
Oh I forgot to mention, for payment of services rendered....you owe us first print pictures....
Good to hear that its all fine now, I have been triple checking the wiring and connections
I'd hate to go through all the pain....
What he said, where's the first print pictures
Bob
Delta's are the way!
hahaDavidF wrote:Oh I forgot to mention, for payment of services rendered....you owe us first print pictures....
Indeed lolcrocky wrote:Good to hear that its all fine now, I have been triple checking the wiring and connectionsI'd hate to go through all the pain....
