Duel extruder problem
maverick
Post by maverick » Tue Aug 13, 2019 2:40 pm
I have an Artemis 300 and have been printing for a few weeks fine. I can use duel extrusion if I point the second extruder to print the raft.
Now when I try to do it with a model I get the following error when it is time to switch to the second extruder.
"Warning: Tool 1 was not driven because its heater temperatures were not high enough or it has a heater fault"
The arms keep moving but no filament comes out. I sliced in Cura with Duel Extruder Profile and made the stand bye temperature 200.
Am I missing something ??
ULTIMATE 3D JEDDI
Re: Duel extruder problem
Post by geneb » Wed Aug 14, 2019 7:36 am
Where did you get the dual extruder profile?
maverick
Post by maverick » Thu Aug 15, 2019 12:44 pm
I got it off the github. It is the batarang thing, and that printed fine, this error is when I try and do my own model.
SeeMeCNC_Artemis_QuickStart_Dual_PLA_050Nozzle_Batarang_for_CURA_4-2-1
ULTIMATE 3D JEDDI
Post by geneb » Fri Aug 16, 2019 7:31 am
When you load that profile sans batarang, does it show you the two extruder tabs on the right? (see example below)
Do you have temps set in both tabs and specific model sections assigned to the respective extruder tabs?
maverick
Post by maverick » Mon Aug 26, 2019 1:54 pm
Yes, both of the temperature settings match for extruder 1 and 2, 200 degrees basically for all the temps.
I wonder if I should up the temp ?
ULTIMATE 3D JEDDI
Post by geneb » Tue Aug 27, 2019 7:35 am
I suspect you're missing a setting or something. I'd email Andy at support@seemecnc.com - he's the dual extrusion expert.
