Extrude is choppy - broken into segments and not complete.
hcdbey
Post by hcdbey » Sat Jun 08, 2019 1:16 pm
Rostock Max V2.
MatterControl 1.7.5
Previously, when I would select a manual 10 mm extrude, it would extrude for about 5 seconds and I would get 10 mm. Now, it is very inconsistent.
If I now select 10 mm, it may extrude 1 or 2 mm pause and then extrude a few more millimeters but not enough to make 10 mm.
Similarly, if I select a 100 mm extrude, it will have perhaps 4 or 5 bursts and it will result in less than 100 mm being extruded.
Does anyone have an idea of what is going on and how to fix it?
ULTIMATE 3D JEDDI
Re: Extrude is choppy - broken into segments and not complete.
Post by geneb » Sun Jun 09, 2019 10:55 am
Try using Repetier Host and see if you get a different behavior.
