[Solved] HE280 reading DEF after install on v2
noname117
Post by noname117 » Mon Feb 11, 2019 2:31 am
So I just installed a HE280 on my v2 and installed the firmware. However, whenever I switch on the printer, the screen briefly shows something around -2 deg on the hot end then goes to def. Double checked the wiring, and soldering on the accelerometer pcb and it all looks good. Anybody know why the hot end thermistor isn't reading?
Solution:
I replaced the thermistor and completely re did some of the crimp connectors on the rambo and the thing is working again.
ULTIMATE 3D JEDDI
Re: HE280 reading DEF after install on v2
Post by geneb » Mon Feb 11, 2019 8:21 am
There's a wiring issue with the thermistor. Check to make sure that the whip connector is fully seated in the HE280 PCB and that all the pins are fully seated in that connector as well as the connectors on the other end.
noname117
Post by noname117 » Mon Feb 11, 2019 8:12 pm
Double checked the wires again and even ran new wires from the pcb to the start of the whip but its still reading def.
ULTIMATE 3D JEDDI
Post by geneb » Tue Feb 12, 2019 9:51 am
There's a wiring issue or the thermistor is bad. You can check the thermistor by measuring its connection point on the PCB with a multimeter. It should read around 100k-ish at room temperature.
noname117
Post by noname117 » Tue Feb 12, 2019 10:06 pm
So I measured everything. Across the thermistor wires going to the accelerometer pcb, it read about 14 v at .02 a and no resistance. Across the green and white wires plugged into T0 on the Rambo, it read about 5 v with no current or resistance.
ULTIMATE 3D JEDDI
Post by geneb » Wed Feb 13, 2019 7:45 am
A thermistor is a resistor that changes resistance with temperature. Testing it's condition by measuring voltage going through it is like measuring the diameter of a car tire by checking the internal pressure. ;)
Don't test the thermistor with the RAMBo powered up, or with the thermistor connected to it. If it's connected to the RAMBo, you'll never get a good reading.
noname117
Post by noname117 » Wed Feb 13, 2019 11:40 am
Tested the resistor again and it read about .715 k across the thermistor leads.
Tested another glass thermistor i had and it read about 179k. Looks like im replacing a thermistor.
noname117
Post by noname117 » Wed Feb 13, 2019 3:30 pm
Wired a new thermistor in but its still reading -3 deg on start up before cutting to def. The thermistor reads about 135 k on the multimeter
ULTIMATE 3D JEDDI
Post by geneb » Thu Feb 14, 2019 9:05 am
You might want to contact support at this point. I don't have any other suggestions, sorry.
Doug68
Post by Doug68 » Tue Feb 19, 2019 9:40 pm
Is this the revision with or without the thermal fuse? If it is check that and check that the circuit through the heater is not open circuit.
Also check the resistances from the solder on the board in case of a dry join, the thermistor wires are so small that may be an issue.
Also I ruined a board by pulling the track off of the board during re-soldering so don't be a gorilla like me.
rootboy
Post by rootboy » Fri Mar 08, 2019 7:58 pm
The thermistor is connected in series with another resistor that's sized to make the thermistor run in its "sweet-ish spot" when it's at its working temperature. There's a good chance that this resistor is bad.
That said, one of the things that I would be squeamish about is mucking around with thermistor circuitry. Unless you just absolutely had to have a new house...
