alternate print bed
euroflo
alternate print bed
Post by euroflo » Sun Apr 13, 2014 4:45 am
Hi All
I though I would just share what could be an alternative to the glass print bed.
I was having alot of trouble with the glass not being flat when heated, so had a thought about what I could use that would stay reasonably flat when heated.
Well I just happen to have some 8mm thick mild steel plate around, so cut some up and bolted her on.
Hey presto, it is flat ( although could do with a quick lick on a surface grinder) and stays flat when heated.
It seems to maintain a very constant temp, although it takes a little longer to get there.
The power light is flickering so it doesnt seem to be working the power supply too much
I have only been running at 70deg so far, but it looks good.
And with a quick spray with the Extra Hold hairspray, prints seem to be sticking.
Well I will see how it goes and let you know if there are any problems.
cheers.
ULTIMATE 3D JEDDI
Re: alternate print bed
Post by Eaglezsoar » Sun Apr 13, 2014 6:59 am
euroflo wrote:Hi All
cheers.
We have many who have used aluminum for a heat plate but rarely steel, I would like to hear how well it performs for you.
euroflo
Post by euroflo » Wed Apr 16, 2014 5:46 pm
Well so far so good. All the prints are staying stuck to the plate, no curling up at the edges, and I am printing to the edge of the plate.
It took 5 mins to heat up to 60 deg, but couldnt get it up to 100 deg. Maybe need to try with 24 V. or enclose the chamber.
Will have to look into that when I get back to printing with ABS.
cambo3d
ULTIMATE 3D JEDDI
Post by cambo3d » Wed Apr 16, 2014 7:41 pm
cheers.
I'm willing to bet that it wasn't your glass that's bowing... 99% positive.
onyx pcb.. on the other hand will bow when heated and cause your glass wobble/ seem like its bowed.
euroflo
Post by euroflo » Wed Apr 16, 2014 8:56 pm
Hi Cambo
Yes that was what I was refering to when I said " the glass not being flat when heated "
The onxy is the main problem, hence the steel plate that it cannot bend
ULTIMATE 3D JEDDI
Post by Eaglezsoar » Wed Apr 16, 2014 10:20 pm
To Cambo3d, it's good to see you on the board again! I've missed you not being around much.
