Fly-n-Strude from Trick Laser
bvandiepenbos
Re: Fly-n-Strude from Trick Laser
Post by bvandiepenbos » Wed Feb 18, 2015 11:28 pm
Finally got a few (7) "Fly-N-Strude" hanging extruder kits made up and available for purchase.
http://www.tricklaser.com/Fly-N-Strude- ... YNSTRD.htm
Shizuma
Post by Shizuma » Fri Feb 20, 2015 9:43 am
Is there any issues with high speed printing with that extra mass on the carriages? Just wondering since I know that's reason for the extruder being mounded stationary with the Bowden tube, of course I imagine this would have significantly less effect on it than mounted direct onto the effector platform, but curious none the less cause this does seem like a great idea, especially for flexible filaments.
Nylocke
ULTIMATE 3D JEDDI
Post by Nylocke » Fri Feb 20, 2015 9:47 am
The point is low moving mass, and since most of the time you aren't moving the carriages vertically that much the mass being thrown around is still minimal.
ULTIMATE 3D JEDDI
Post by Jimustanguitar » Fri Feb 20, 2015 10:01 am
Shizuma wrote:Is there any issues with high speed printing with that extra mass on the carriages? Just wondering since I know that's reason for the extruder being mounded stationary with the Bowden tube, of course I imagine this would have significantly less effect on it than mounted direct onto the effector platform, but curious none the less cause this does seem like a great idea, especially for flexible filaments.
I've been printing at 100mm/s lately (which is approaching the limit for my .4mm nozzle). No ill effects to report.
ULTIMATE 3D JEDDI
Post by mhackney » Fri Feb 20, 2015 11:13 am
Shizuma, like most things in life, it's a tradeoff. Low mass is good, long Bowden tubes with hysteresis and slop is not good. One is a trade off against the other.
Shizuma
Post by Shizuma » Fri Feb 20, 2015 4:00 pm
Jimustanguitar wrote:I've been printing at 100mm/s lately (which is approaching the limit for my .4mm nozzle). No ill effects to report.
That's good to know, I often print at 90mm/s with ABS so that's why I was curious, I would like to get into printing some flexible materials as well though so this mod would definitely be nice for that.
jmpreuss
Post by jmpreuss » Fri Feb 20, 2015 8:26 pm
Is this for the Max only or does it work for the Orion too?
Nylocke
ULTIMATE 3D JEDDI
Post by Nylocke » Fri Feb 20, 2015 8:56 pm
Looks Orion compatible, just shorten the elastic and bowden tube.
ULTIMATE 3D JEDDI
Post by Jimustanguitar » Fri Feb 20, 2015 10:48 pm
jmpreuss wrote:Is this for the Max only or does it work for the Orion too?
Yep, the Orion uses the same EZStruder and carriage mounts, so these would work on either model.
predawnsky
Post by predawnsky » Sat Feb 28, 2015 8:09 pm
I just ordered mine, cant wait to get it
predawnsky
Post by predawnsky » Sat Mar 07, 2015 1:58 pm
Jimustanguitar wrote:TL is going to cut the first batch and try to have them online sometime next week.
how tight do you have the bungies
oh and do you know why im getting a def reading on my temps
ULTIMATE 3D JEDDI
Post by Mac The Knife » Sat Mar 07, 2015 2:13 pm
def reading on your temps means you have a thermistor disconnected,,, most likely the one for the hot end.
predawnsky
Post by predawnsky » Sat Mar 07, 2015 4:37 pm
Mac The Knife wrote:def reading on your temps means you have a thermistor disconnected,,, most likely the one for the hot end.
Funny thing is its all connected and when I turn it on it says 366 for the nozzle and the def
ULTIMATE 3D JEDDI
Post by Mac The Knife » Sat Mar 07, 2015 5:00 pm
It must be shorted then,,,,, I'd check the wiring at the thermistor on the hotend. It takes more abuse then the thermistor on the bed.
RegB
Post by RegB » Sat Mar 07, 2015 7:42 pm
or the heated bed thermistor.
I blundered right through this when I first built mine;
I *ASSUMED* that def was probably an abbreviation for "def_ault" :D
Nope, it means "def_ect".
ULTIMATE 3D JEDDI
Post by Mac The Knife » Sat Mar 07, 2015 8:22 pm
A reading of 366 for the nozzle and then switches to def? It's not a problem with the bed.
ULTIMATE 3D JEDDI
Post by Jimustanguitar » Sat Mar 07, 2015 9:26 pm
predawnsky wrote:how tight do you have the bungies
Sounds like others have helped on the default reading.
For the bungees, just print something relatively large, and anytime you see a cord sag with slack, just pull out that little bit. No need to be tight, just remove the slack and it'll work great.
redoverred
Post by redoverred » Sat Mar 07, 2015 10:21 pm
Defect can also mean that you are using the wrong pins in Repetier firmware to read temps.
predawnsky
Post by predawnsky » Sun Mar 08, 2015 12:43 pm
so ive checked everything and it all looks good except for this, im starting to use simplify
RECEIVED: extruder 0: temp sensor defect
RECEIVED: heated bed: working
RECEIVED: Error:Printer set into dry run mode until restart!
RegB
Post by RegB » Tue Mar 10, 2015 7:52 am
626Pilot wrote:
teoman wrote:626Pilot, why would the extruders need to be on the arms, why not have them on the carriages.
Putting them on the arms brings them closer to the hot end and lets me center the EZ-Struder output relative to the effector as well as I can. It goes out of center as the effector moves toward the edge, but it's still pretty good. In this configuration, it also doesn't get in the way of anything. Putting it on the carriage would move it further away and make it harder to keep the filament path as minimally curved as possible, because it would have to be mounted to the left or right of the carriage. The more degrees of curvature, the more friction. It can't be mounted above or below the carriage because the endstops are upstairs, and the bottom plate is downstairs.
There is a slight issue with the extruder mount creeping down the arms over time, even if the apparatus is tightened properly. I think a little hairspray on the arms and on the outside of the heat shrink tubing ("vibration mount") would fix that properly.
Also, this mod makes the extruder Q-U-I-E-T! You have to be sitting next to it to hear anything at all. Retracts are whisper-quiet and skipping, which could be heard through a closed door before, is just a quiet thud.
I like it.
In particular I like that it allows a 3 (or 4) extruder set up - it doesn't "make it all happen", but doesn't preclude it.
How would a very short bowden tube work ?, so short that there is NO bending ?
I'm thinking;
a) take the WEIGHT off with a string straight up through the middle hole that the wiring currently comes through, 90 degrees over a pulley, out to the edge, 90 degrees over another pulley and down to a counter weight.
Maybe even MORE counter weight than the actual extruder, effector and hot end weight ??
b) keep it from flopping side to side with very light bungies tied to the arms at ...whatever position keeps them about horizontal.
Brian DOES do good work, his prices are good, so I might just order from TL (& quit my arm chair design criticizing)
predawnsky
Post by predawnsky » Wed Mar 11, 2015 6:17 pm
fixed it thermostat went bad
Jassper
Post by Jassper » Fri Mar 20, 2015 10:11 am
Is that open source?
The MakerHive
Berd-Air Cooling Kit
The MakerHive Store
bvandiepenbos
Post by bvandiepenbos » Fri Mar 20, 2015 11:06 am
Jassper wrote:Is that open source?
I can email you the dxf if you want. pm me your email.
jarek319
Post by jarek319 » Sat Feb 13, 2016 1:45 pm
bvandiepenbos wrote:Finally got a few (7) "Fly-N-Strude" hanging extruder kits made up and available for purchase.
Just picked one up on backorder :)
Any estimates on when it will be back in stock? I've been having some issues lately with my extrusions and I think this might help.
barry99705
Post by barry99705 » Mon Feb 29, 2016 11:10 pm
How are you keeping everything homed after a print? The weight is making mine drop to the floor, which is bad with a hot nozzle hitting the printed object.
Return to “Mods and Upgrades”
