Why Dual Extruders
ULTIMATE 3D JEDDI
Why Dual Extruders
Post by Eaglezsoar » Mon Jan 06, 2014 3:48 pm
I have a continuing battle going on with myself about if I should upgrade to dual extruders on my Max or stay with one extruder.
I realize that the dual gives you the ability to print with two colors or use one for a cheap or desolvable supports.
Have anyone also battled with themselves about this decision and what did you decide and why? I am using one E3D if it matters.
Batteau62
Re: Why Dual Extruders
Post by Batteau62 » Mon Jan 06, 2014 4:23 pm
Do not feel alone, my original plan was always dual extrusion. I even still have double of all the stock parts for it. My "fear" is if I mess with my max, which prints nicely, I won't get it back if I break it. My plan is to save up and buy a second one. That way I'll have a " sand box" to play in :D
int2str
Post by int2str » Mon Jan 06, 2014 4:32 pm
I am very keen on dual extruders, mainly for desolvable supports. In theory, desolvable supports opens up a whole new range of printable objects. My son is very interested in printing video game models/characters, which are far too complex to print without good supports that are easy to remove.
So I will likely go dual extrusion simply for desolvable supports.
I hope I'm not putting too much faith in them...
dpmacri
Post by dpmacri » Mon Jan 06, 2014 5:04 pm
I always wanted to go to dual extrusion for the dissolvable supports, plus the option of printing in two colors. Having just got my MAX back in August, I *requested* an "Add-a-struder" kit for my birthday in October. But then I also ordered an E3D hot-end before I ever setup the dual extruders, and made another *request* for a second E3D hot-end for Christmas, which I got. As I've posted elsewhere, I have two E3D extruders mounted, now, but I'm struggling to get a decent print because one of the nozzles ends up a few fractions of a millimeter higher (maybe .2) than the other :-P. So I need to alter my mount to try to get them to the same height. Or, sigh, wait and go with a Kraken which has the nice mechanism for adjusting the nozzle heights :-D.
Anyway, like Batteau62 fears, my setup is currently in a semi-working state because of my switch to dual extruders. I haven't had the time to sit down and figure out the best way to adjust one of the nozzle heights.
ULTIMATE 3D JEDDI
Post by Eaglezsoar » Mon Jan 06, 2014 5:09 pm
dpmacri wrote:I always wanted to go to dual extrusion for the dissolvable supports, plus the option of printing in two colors. Having just got my MAX back in August, I *requested* an "Add-a-struder" kit for my birthday in October. But then I also ordered an E3D hot-end before I ever setup the dual extruders, and made another *request* for a second E3D hot-end for Christmas, which I got. As I've posted elsewhere, I have two E3D extruders mounted, now, but I'm struggling to get a decent print because one of the nozzles ends up a few fractions of a millimeter higher (maybe .2) than the other :-P. So I need to alter my mount to try to get them to the same height. Or, sigh, wait and go with a Kraken which has the nice mechanism for adjusting the nozzle heights :-D.
May I ask what mount you are using for the two E3D hot-ends?
dpmacri
Post by dpmacri » Mon Jan 06, 2014 5:12 pm
The one I created: http://www.thingiverse.com/thing:217662
foshon
Post by foshon » Tue Jan 07, 2014 4:56 pm
IIRC Slic3r allows for offsetting the z height of each nozzle separately.
Purple = sarcasm
dpmacri
Post by dpmacri » Tue Jan 07, 2014 5:20 pm
That would be interesting, but I don't see how it could work. If I want to just print with the one nozzle that has a higher z height, that will drive the other nozzle into the bed for the first layer :-P. Looking at the Slic3r config now, I see that there's a global "Z offset" which basically allows you to compensate for your Z=0 layer actually being slightly off.
foshon
Post by foshon » Tue Jan 07, 2014 5:34 pm
It's quite probable my memory sucks. :lol: Have you thought about machining the top of the nozzle?
Purple = sarcasm
dpmacri
Post by dpmacri » Tue Jan 07, 2014 8:03 pm
foshon wrote:It's quite probable my memory sucks. :lol: Have you thought about machining the top of the nozzle?
That's a good thought, too, but what I really plan to do (as soon as I get the time to work on it) is just to measure the offset and then modify my dual E3D mount to account for it. My fear is that if I mess with the nozzle, I'll screw it up beyond repair :-P.
Return to “Mods and Upgrades”
