From the description, the arms state they are approximately 1mm longer and require minimal firmware changes.
I increased the diagonal Arm Length from 178 to 179.
When calibrating the towers, I got them close to no deviation between the towers. Using a digital dial gauge, I have one tower that is 0.01mm lower than the rest.
Is that an amount worth wrestling with the end stop screw to alleviate? Adjusting those seem to be quite tedious to bracket in and I felt quite happy with that range.
I adjusted the Horizontal Radius through trial and error and eventually got across the center and towers the following measurements:
Top
0.00
Center
0.00 0.00
Left RightThe Horizontal Radius had increased from 74.3 originally to 88.45. Does that value make sense? I was quite surprised that a 1mm Diagonal Arm Length change had a 14.15mm impact on Horizontal Radius.
Anyways, my dilemma started when I ran Radius.gco
Left side -.28mm Center 0mm Right side .28mm
How can this be? If all the towers are zeroed, I don't understand how there can be a .56mm range from left to right.
Any thoughts?
Thank you!
I am not sure how I can be getting this
