3d model slicer software
predawnsky
Post by predawnsky » Fri May 22, 2015 9:01 am
do you guys to know where I can get a 3d model slicer software to make prints more manageable for my printer
ULTIMATE 3D JEDDI
Re: 3d model slicer software
Post by Mac The Knife » Fri May 22, 2015 9:57 am
Define "manageable".
predawnsky
Post by predawnsky » Fri May 22, 2015 11:31 am
With in the 11x14 space for my max v2
I have a massive build I want to do but I need to slice it into smaller pieces that my printer can handle
ULTIMATE 3D JEDDI
Post by Mac The Knife » Fri May 22, 2015 12:10 pm
Ahhh, Now I see,,,, you're looking for software to cut your model up into smaller sections that your slicer can generate code to fit the Rostock.
Dale Eason
Post by Dale Eason » Fri May 22, 2015 12:42 pm
You can do that with MeshMixer, 123D, and FreeCad to name a few. I use 123D.
predawnsky
Post by predawnsky » Fri May 22, 2015 2:10 pm
Dale Eason wrote:You can do that with MeshMixer, 123D, and FreeCad to name a few. I use 123D.
what version of 123d do you use
Dale Eason
Post by Dale Eason » Fri May 22, 2015 6:11 pm
1.6.41 but the version should not matter they have had the split solid function for a long time I think.
ULTIMATE 3D JEDDI
Post by Mac The Knife » Fri May 22, 2015 7:07 pm
predawnsky
Post by predawnsky » Fri May 22, 2015 9:25 pm
thanks mac
teoman
ULTIMATE 3D JEDDI
Post by teoman » Sat May 23, 2015 3:38 am
Might want to add little holes and protrusions so it self aligns or better yet little tabs so it "clicks" back in to place.
predawnsky
Post by predawnsky » Sat May 23, 2015 5:39 pm
will do teoman
RegB
Post by RegB » Mon Oct 08, 2018 8:18 pm
Ahh yes, "massive" builds".
Not usually the domain of 3D printing, but it CAN be done.
I'm going through this now, since the PRACTICAL limit on ABS prints is about 10 cm - above that thermal stress and shrinkage cause cracking and/or deformities.
Solidworks can do it; basically you would need to design in the "joints", create assemblies from parts and use "mate".
Expensive unless you can get a student or ex military service purchase - or already have it funded for some other project.
RegB
Post by RegB » Mon Oct 08, 2018 8:23 pm
I can't edit the above post, but had meant to say that in Solidworks "mate" will help you figure out where and how your joints don't fit, e.g. a sliding dovetail needs to be right, and I mean JUST RIGHT for the assembly to go together.
It can still be worth taking off a TINY bit from each mating surface to allow for slight outer wall irregularities - or you'll be filing plastic.
ULTIMATE 3D JEDDI
Post by Xenocrates » Thu Oct 11, 2018 5:39 pm
Netfabb is pretty easy. I've attached the archived free installer (since pulled from the website, but it should still work). I've done some stuff with it, as well as using Maya and Fusion 360 for similar tasks, but Netfabb is way easier to just split things.
netfabb-free_6.4.0_win32.zip
(22.32 MiB) Downloaded 4 times
Return to “Other”
