Greetings from the PNW
waynebuilt
Post by waynebuilt » Mon Jan 23, 2017 8:06 pm
Got my V3 over the holidays, diy kit. Build went without hitch, hot end working just fine, heated bed not so well, after trouble shooting with tech we determined the bed was defective, second bed was received, works much better but still not warming up to my desired temp 100c.
morgandc
Re: Greetings from the PNW
Post by morgandc » Mon Jan 23, 2017 9:47 pm
Welcome, perhaps print on something other than glass to make it so printing on a 75degree bed is ok? That or go 24v on the bed.
ULTIMATE 3D JEDDI
Post by Mac The Knife » Tue Jan 24, 2017 7:25 am
What material are you trying to print with?
ULTIMATE 3D JEDDI
Post by geneb » Tue Jan 24, 2017 8:52 am
FYI, there's zero reason to need 100C on a heated bed.
waynebuilt
Post by waynebuilt » Tue Jan 24, 2017 11:03 am
geneb wrote:FYI, there's zero reason to need 100C on a heated bed.
Well I'm printing xt-cf20 so there is a need for higher bed temps. I got the HB dialed in, holding 100c with some pid tuning.
morgandc
Post by morgandc » Tue Jan 24, 2017 8:09 pm
Wow! is that 100c with the fans running?
NormL1
Post by NormL1 » Wed Jan 25, 2017 6:29 pm
Welcome fellow PNW'ener! I have insulated my bed with foam and now doing the 24v to the bed. The bad part of the foam is that it is hard to keep cool enough for TPU to stick. I wish that I had just done the 24v, but, I can scrape the foam out
Rostock Max V3, 24v, Prometheus and 713maker, AON-M big printer, Mosaic Palette (since it only does PLA, trying to decide what to do with), Prusa i3 MK2 w/4 extruders (waiting), HDS6200 surveying laser scanner and two older surveying laser scanners
morgandc
Post by morgandc » Thu Jan 26, 2017 10:33 pm
I insulated mine with reflective insulation, heats up much faster than stock but at last test I couldn't get anywhere near 100 with any fans running.
vrenlos
Post by vrenlos » Fri Feb 03, 2017 1:02 am
Hello, fellow PNW'er! I'm also new to the club, but my V3 is working a treat so far. Enjoy and congrats!
ULTIMATE 3D JEDDI
Post by geneb » Fri Feb 03, 2017 7:58 am
At some point, we should really get together and have a PNW rmax gathering...
bubbasnow
ULTIMATE 3D JEDDI
Post by bubbasnow » Fri Feb 03, 2017 10:24 am
geneb wrote:At some point, we should really get together and have a PNW rmax gathering...
I agree, I could always use an excuse to head to the other side of the mountains besides to refill on korean food in tacoma.
