Ungroup Model/STL
http://www.123dapp.com/
KAS
ULTIMATE 3D JEDDI
Ungroup Model/STL
Postby KAS » Mon May 18, 2015 8:17 pm
This might not be possible, but does anyone know how to ungroup an STL file in 123D ?
The E3D v6 mount has both the Top and Bottom sections in one STL file.
stonewater
Re: Ungroup Model/STL
Postby stonewater » Tue May 19, 2015 11:40 am
try using meshmixer, I have had zero success in doing anything with 123D once it renders an STL file. I like using it, but I always save the drawing in the 123D file format so I can edit later, I usually save several times after I make a modification so I have several places to re enter the drawing process.
Tom C
MAX V1
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
ULTIMATE 3D JEDDI
Postby Jimustanguitar » Tue May 19, 2015 3:05 pm
Some slicers will let you split up multi-object files, and you could save the parts afterwards.
In DesignSpark, when you import an STL, if it's separate objects, you can split them after the import.
KAS
ULTIMATE 3D JEDDI
Postby KAS » Tue May 19, 2015 3:37 pm
Okay, I wanted to give it a try but I guess I'll go back to DSM.
bvandiepenbos
Postby bvandiepenbos » Thu May 21, 2015 12:03 pm
You can split it apart in netfabb
VAXHeadroom
Postby VAXHeadroom » Sat Jul 18, 2015 10:54 am
123D isn't much more than a viewer for STL files. You can copy and delete the portions you don't want, but it's REALLY REALLY SLOW.
So for this example, make a copy (CTRL-C),(CTRL-V), move it over one direction a few inches/cm so the original and the copy don't overlap, then draw a sketch circle under the portion you want to delete from the first copy and extrude it THROUGH the pieces you don't want. The default behavior is SUBTRACT which will delete anything inside the new cylinder. It's slow, but should work.
As other have said, there are better tools for this operation on STL files!
bot
Postby bot » Sat Jul 18, 2015 2:36 pm
With meshmixer you simply click Edit (on the side) ---> separate shells.
*not actually a robot
Return to “AutoDesk 123D”
Who is online
