V4 / Duet2 / KISSlicer / DUAL EXTRUSION Y-bowden FEED and RETRACT?
nurbie
Post by nurbie » Fri Jul 26, 2019 5:23 pm
V4 set-up as above
KISSlicer Premium v1.6.3
I have dual enabled in the Duet config
Bear with me here, I've had multi-extruder KISS for one day, and this is my first dual extrude.
How the heck do you get the filament to feed and retract?
I just don't know where to start with the whole retraction/feed issues
According to the SMCNC CURA setup you pull the filaments away from the Y-connector 40mm to start.
This would imply that something then tells the machine to push/pull the filaments accordingly.
Help me make a new SMCNC Guide for KISS community!
NO idea if I need to modify KISS, Duet config, or BOTH?
I've got KISS generating a test with short pillar:
Guessing magic has to happen here:
and here:
CAN SOMEONE PLEASE POINT ME IN THE RIGHT DIRECTION/S?
There must be some documentation somewhere on how this is achieved as you guys have been doing multi-extruder prints for at least 2years, right?
Hopefully I can lure Hackney(HA!)
get it?
cast,
tug, tug, tug
Thanks in advance!!
UPDATE:
I got the Printer and Extruder settings from SMCNC for CURA, so if I put them into KISS correctly they should work(?)
Can anyone point out the correct KISS locations for these?
per email:
The code in the machine settings(first pic) is where the filament prime, retracts, and at the end retract back so both filaments are above the Y are set up.
I've got this so far:
nurbie
Re: V4 / Duet2 / KISSlicer / DUAL EXTRUSION Y-bowden FEED and RETRACT?
Post by nurbie » Sat Jul 27, 2019 8:48 pm
well, this doesn't work:
KISSLICER DUAL CONFIG TEST_01
PREFIX
; [mm] mode
G21
; absolute mode
G90
; Home
G28
; Heated bed control
M140 S<BED>
; Absolute E
M82
M203 Z24000
G28 ;HOME
G1 Z15.0 F6000 ;MOVE PLATFORM DOWN 15MM
;PRIME EXTRUDER
G92 E0
PREHEAT
; heat the (next, then current) extruder without waiting
;M104 S<TEMP> T<EXT+0>
; Uncomment the previous line to enable preheat
SELECT NEW EXT & WARM
; Select new extruder
T<EXT+0>
; Warm it up, and wait till it's warm
M109 S<TEMP>
; You may want to prime some filament here
G1 X0 Y70 F20000
T0 PO
G92 E0
G1 E160 F3000
G92 E0
M18 E1
WARM SAME EXT
M109 S<TEMP>
COOL SAME EXT
; Cool it, no need to wait
M104 S<TEMP>
COOL & RETIRE OLD EXT
; Deselect the (same) extruder (usually to cool)
M104 S<TEMP>
; PREP EXTRUDER FOR SWAP + RETRACT FILAMENT
G1 X0 Y70 F20000
G91
G1 Z1 F20000
G90
G92 E0
G1 E-160 F5000
G92 E0
N [*] LAYERS
; Maybe re-home X & Y?
POST FIX
; Maybe cool the bed?
M140 S0
; Maybe move to some safe location?
G1 F1200 X0 Y0 Z<Z+5.0>
M104 S0
M140 S0
;RETRACT ALL FILAMENT
G92 E1
G1 E-160 F3000
G28
M84
M203 Z24000
PAUSE & RESUME
; Pause then Resume
; usually M0 (typical) or M1 (less common) or M226 (least portable)
M0
I also tried putting the second extruder's gcode in the Material Gcode section for the E1 ext material...
Doesn't work
Return to “KISSlicer”
