Gcode from slicer is not heating extruder
A place to talk about slic3r software (http://slic3r.org)
Koops
Post by Koops » Sun Jul 03, 2016 7:56 pm
I've been through all the settings and the config wizard and no matter what I seem to do, I cannot get the gcode from Slic3r to heat the extruder.
Help appreciated
IMBoring25
Re: Gcode from slicer is not heating extruder
Post by IMBoring25 » Sun Jul 03, 2016 8:03 pm
Have you set the start g-code to the same as the start g-code from MatterControl?
I'm not sure if MatterControl is the same (it crashed 100% of the time on the machine I was using when I finished the printer, so I went to Repetier Host for it and haven't looked back), but Repetier-Host with default settings adds start and finish gcode of its own that are incompatible to imported gcode. You may need to disable this.
Koops
Post by Koops » Sun Jul 03, 2016 8:11 pm
IMBoring25 wrote:Have you set the start g-code to the same as the start g-code from MatterControl?
I will take a look at this and get back to you, thank you very much for your guidance, it has been invaluable!
Tincho85
Post by Tincho85 » Sun Jul 03, 2016 8:44 pm
Repetier-Host rocks.
If you can't solve it, install Rep H and use the built-in slic3r or the Cura engine. They both work great.
Here is a guide.
https://mega.nz/#!7RxVXTiS!3OIVH4sTLGzqb7l2iwrXRviUAL-yVUIhH_h_B9FqfK8
Martín S.
Koops
Post by Koops » Tue Jul 05, 2016 6:58 pm
Hey guys, downloaded r-host and set everything up and still nothing with regards to it heating the extruder, target remains 0 on lcd screen, heats the bed though
I am able to manually control the extruder before initiating a print, but once I initiate a print, there is no target for the extruder and it is unresponsive to gcode commands or manual control via r-host
Koops
Post by Koops » Tue Jul 05, 2016 8:27 pm
Managed to solve it with some fiddling, no idea what the problem was in the end though, just deleted pre sets and reconfigured a few times as well as restart both comp and printer
Post by Xenocrates » Tue Jul 05, 2016 9:02 pm
Is this with a duet controller or similar?
Koops
Post by Koops » Wed Jul 06, 2016 8:47 am
Xenocrates wrote:Is this with a duet controller or similar?
Running the standard rambo if thats the right answer?
Still unable to get the fans running during bridging!
Koops
Post by Koops » Wed Jul 06, 2016 8:49 am
This is becoming a running commentary, managed to get the cooling working! Only works during a lower layer height though?
Return to “Slic3r”
