Simplify3D profile for stock Rostock MAX v3.2?
This forum is for discussions specific to the Duet-equipped Rostock MAX v3.2 3D printer.
TedMilker
Postby TedMilker » Thu Sep 13, 2018 6:58 pm
Anyone have a profile they'd share for Simplify3D for stock Rostock MAX v3.2?
ULTIMATE 3D JEDDI
Re: Simplify3D profile for stock Rostock MAX v3.2?
Postby geneb » Fri Sep 14, 2018 8:05 am
The attached is for the Artemis, but it should work fine on the 3.2. Jim Carter built it.
Artemis.txt
(11.63 KiB) Downloaded 7 times
You'll need to change the extension from "txt" to "fff".
TedMilker
Postby TedMilker » Fri Sep 14, 2018 6:45 pm
Thanks geneb!
ULTIMATE 3D JEDDI
Postby geneb » Sat Sep 15, 2018 11:43 am
You're welcome!
jcarlin
Postby jcarlin » Sun Sep 16, 2018 8:33 pm
Been working on this Rostock Max v3.2 FFF for Simplify3D and I am pretty sure its just about there. I took a mix of the standard Simplify3D profile for the RMAXv3, the proposed settings for Cura from SeeMeCNC and the settings for the Artemis. It prints very nicely on my freshly upgraded v3.2. You might need to tweak the temps for your own liking.
I also included a bonus! Messing around I figured out how to add the Rostock base under the build plane. The .stl and where to put it are included in the zip file. Move the file into place before you import the FFF.
Example image: https://drive.google.com/file/d/1gwIcXZVLACP-AzHsV-jv72wl5h-D5CjV/view?usp=sharing
Here are the files:
RMAXV32_SIMPLIFY3D.zip
(800.08 KiB) Downloaded 3 times
R-Max v3.2 (upgraded)
Powerspec Ultra
Simplify3D
jcarlin
Postby jcarlin » Thu Sep 20, 2018 7:50 pm
I have a new version of my S3D FFF for the v3.2...
Spent most of the day tweaking the settings until I virtually eliminated my stringing. Still dialing everything in, but thought I would share my work in process.
SeeMeCNC Rostock Max v3.2 version 2.fff.zip
(3 KiB) Not downloaded yet
Powerspec Ultra
Simplify3D
Return to “Rostock MAX v3.2”
Who is online
