Filament run out monitor
firebass08
Postby firebass08 » Tue May 01, 2018 4:48 pm
I'm considering a filament check.
What would y'all recommend or use for a filament check?
The duet monitor or just a switch or other?
https://duet3d.dozuki.com/Wiki/Duet3dFi ... netVersion
https://www.thingiverse.com/thing:2577717
kraegar
Re: Filament run out monitor
Postby kraegar » Wed May 02, 2018 9:12 am
I'm waiting to test out the new duet monitor when it's available (or they send me one).
I've not ever actually used a filament monitor to be able to recommend anything specific, though.
ULTIMATE 3D JEDDI
Postby Xenocrates » Wed May 02, 2018 9:48 pm
It depends on your use case and failure modes. If slipping is a problem for you, a filament monitor can help a lot. Same with jamming.
A simple switch only detects breaks, and running out of filament. Now, for say, a college using cuts off of spools, a switch handles most failure modes I've seen (as the students mostly don't get to print with a full spool, nor for longer than a few hours, so anything lost isn't that bad, but being able to use the whole off-cut is much better for our budget).
For longer prints, or ones with more expensive filaments, a filament monitor is much better, because it will pause it if it jams (More likely with the filled filaments, too), or slips (if say, the drive gears are loading up).
Return to “RailCore”
Who is online
