AJAX errors an issue?
The one, the only, the Atremis. Forum for the monster metal machine from SeeMeCNC
Burley
Post by Burley » Sat Mar 31, 2018 12:38 am
This isn't an Artemis specific issue, but it would be nice to have a CAT5 type interface option on the Duet board. In a shop with Mig/Tig equipment, brute force 40/50 Amp machining centers etc. nearby, the spurious RF activity pretty much kills 'wireless'. We had issues on other equipment and finally went with 'hard' data connections to resolve the RF noise problems. An arc is composed of 'all frequencies' so there is no effective filter. A shielded cable solves that problem. Any others having wireless disconnect concerns?
Burley
sandy
Re: AJAX errors an issue?
Post by sandy » Sat Mar 31, 2018 1:47 am
I am, but it also might be the firmware and there is a new release out.
My Artemis as v.1.19 and 1.21 was released last week.
dc42
Post by dc42 » Sat Mar 31, 2018 8:23 am
There is already a Cat 5 option, it's called the Duet Ethernet. AFAIK it's not yet an option on the Artemis.
Burley
Post by Burley » Sat Mar 31, 2018 11:23 am
DC42, Yep, ya got me! :lol:
Burley
ULTIMATE 3D JEDDI
Post by geneb » Sat Mar 31, 2018 12:12 pm
You can buy a Duet Ethernet and drop it right into the Artemis. The wiring connections are identical. You'll need to use the configuration from the Wifi version, with the Wifi commands commented out. The Duet Ethernet docs will show you how to configure it for your network.
You'll also need to either cut a hole in the clear window in front of the Duet or grab the Artemis CAD files from here: https://github.com/seemecnc/Artemis. Open up the file named "26775 Panel Cover REV B for Duet WiFi.IGS" using any design package that can open/edit IGES Files. You can then modify the part to accommodate the Ethernet cable and then print and install it. (Ain't open source grand? :D )
Return to “Artemis”
