FSR-equipped Artemis calibration note.
The one, the only, the Atremis. Forum for the monster metal machine from SeeMeCNC
ULTIMATE 3D JEDDI
Post by geneb » Thu Mar 01, 2018 8:34 am
If you've got an FSR-equipped Artemis 300 and you're having calibration problems, check to make sure your bed clip is clearing the sheet metal chassis as shown in the image below.
The reason for this is that if the clip is in contact with the Artemis chassis, nominal nozzle pressure won't be enough to trigger the FSR at that location, causing either failed probes or excessive nozzle pressure.
adarcher
Re: FSR-equipped Artemis calibration note.
Post by adarcher » Sun Mar 04, 2018 10:41 pm
Thanks for pointing that out. I rushed to check if that was my issue. Sadly it wasn't, but I'll keep it in mind.
Return to “Artemis”
