CURA plugin to print wirelessly to duet board/atermis
magicmarc
Post by magicmarc » Mon Feb 19, 2018 1:31 pm
thanks to the FBook group members, as well as Ryan & Joseph, i was able to overcome some assembly obstacles and time constraints to complete my atremis build. the firstprint.gcode for benchy came out great! better than my current H2 ever has printed!
i read in a post there is a plugin for cura for the artemis/duet wifi? where would i get this from to try out?
thanks again everyone.
m
Magic Marc
ARTEMIS & H2
dc42
Re: CURA plugin to print wirelessly to duet board/atermis
Post by dc42 » Mon Feb 19, 2018 5:47 pm
magicmarc
Post by magicmarc » Tue Feb 20, 2018 9:23 am
thank you!
Magic Marc
ARTEMIS & H2
magicmarc
Post by magicmarc » Fri Mar 02, 2018 9:29 am
hi in installed the duetRRF plugin into cura, and when i goto print to artemis, vie the duetrrf, it gives me a 'network error - protocol'. and when i goto the extension portion of cura to edit the parameters for the duetrrf plugin, its asking for the duet board username and password,,, is there a default username & password for the artemis duet board?
thanks
marc
Magic Marc
ARTEMIS & H2
ULTIMATE 3D JEDDI
Post by geneb » Fri Mar 02, 2018 4:01 pm
Only if you specifically set one.
Paste in your config.g and we'll see what's going on. :)
magicmarc
Post by magicmarc » Sun Mar 18, 2018 6:34 pm
hi gene, i had to reinstall the cure, ill reinstall the duet rff plugin and try again, then ill post the config file.
thanks
marc
Magic Marc
ARTEMIS & H2
magicmarc
Post by magicmarc » Mon Mar 19, 2018 9:49 am
ok, so gene, i tried to install the latest duet-wifi-rff plugin for cura 3.2.1 (Cura-DuetRRFPlugin-0.0.5),
i got this from the link listed below for the cura duetwifi.
basically unzipped the folder, and placed it in the /program files/ultimaker cura 3.2.1/plugins folder but when i oppen cura its not there, not recognizing the plugin added.
any ideas, as i need to install this plugin to try testing again . as well i will check the cura forum to see about installation problems for plugins.
marc
Magic Marc
ARTEMIS & H2
Bones056
Post by Bones056 » Mon Mar 19, 2018 2:31 pm
I believe that you need to change the folder name from Cura-DuetRRFPlugin-0.0.5 to Cura-DuetRRFPlugin-master. That should do it for you....
Bones056
Post by Bones056 » Mon Mar 19, 2018 2:33 pm
Just a heads up on using Cura 2.3.1 with the Artemis.... I had a lot of problems trying to use that version. I had to go back to 3.1.
magicmarc
Post by magicmarc » Mon Mar 19, 2018 2:42 pm
thanks bones, i thought the latest plugin ver 0.0.9 was supposed to work with cura 3.2.1...
ill try changing the name now, and see if it recognizes the plugin!
marc
Magic Marc
ARTEMIS & H2
magicmarc
Post by magicmarc » Mon Mar 19, 2018 3:12 pm
thanks bones, changing the namee of the folder worked, it recognizes there duet rff is there as extension... however when i went to upload a file to the artemis (after editing the correct wifi ip address) it says 'network error "" 301 incorrect protocol... ideas (i am using a sonicwall tz300 as my firewall/wifi, and have it set to pass wan traffic to lan seamlessly... i thought...)
Magic Marc
ARTEMIS & H2
Bones056
Post by Bones056 » Mon Mar 19, 2018 3:26 pm
Sorry... can't help you with that..
magicmarc
Post by magicmarc » Tue Mar 20, 2018 8:08 am
well y'all here always are my saviors, i wish i could help, and down the road ,ill have experience to assist folks here too. im checking the duet3d.com site for me details on the plugin error.
Magic Marc
ARTEMIS & H2
magicmarc
Post by magicmarc » Wed Mar 21, 2018 7:07 pm
the latest plugin version works fine now, v0.0.10
Magic Marc
ARTEMIS & H2
Burley
Post by Burley » Sat Mar 31, 2018 12:10 am
With Cura 3.2.1?
ULTIMATE 3D JEDDI
Post by geneb » Sat Mar 31, 2018 12:14 pm
It works just fine with Cura 3.2.1
Return to “Artemis”
