H2 is a great printer
An affordable delta DIY kit made with high quality electronics/parts/hardware
coyn
Post by coyn » Mon Mar 27, 2017 8:30 am
I built my H2 last week. After putting about 32 hours of print time on it over the weekend, I have to say that this is a great setup. It's my first printer and it went together and prints great.
magicmarc
Re: H2 is a great printer
Post by magicmarc » Tue Mar 28, 2017 7:50 am
what are you using to hold the first layer down to the glass.... ? im using blue painters tape currently with PLAS at 215 degrees... but the ABS is giving me problems sticking down..
Magic Marc
ARTEMIS & H2
ULTIMATE 3D JEDDI
Post by geneb » Tue Mar 28, 2017 10:09 am
magicmarc, unless you've got a heated bed installed, there's no way you can print ABS on the H2.
Adding a heated bed is pretty easy though - you can install the Onyx heated bed for the Orion and then replace your stock power supply with a larger one. I've been told an XBox power supply can be used, but since I don't have the details (yet), I can't give you a recommendation on that.
pouncingiguana
Post by pouncingiguana » Mon Apr 03, 2017 2:41 pm
Washable glue stick on the glass will hold ABS pretty well.
magicmarc
Post by magicmarc » Fri Apr 07, 2017 9:07 pm
i havent heard of the washable glue stick, may i ask which brand makes this? thanks!
marc
Magic Marc
ARTEMIS & H2
ULTIMATE 3D JEDDI
Post by geneb » Sat Apr 08, 2017 9:54 am
Elmer's Disappearing Purple glue stick.
Return to “Hacker Series - H2”
