Prinlter stops At the same spot
An affordable delta DIY kit made with high quality electronics/parts/hardware
harryatgoldrush
Postby harryatgoldrush » Mon Oct 23, 2017 5:28 pm
I have been trying to print the spool holder Tube, it's about five layers in and then stops. The hot end is embedded in the work It won't lgo any farther it's happened three times in the same spot.
Help!
pouncingiguana
Re: Prinlter stops At the same spot
Postby pouncingiguana » Tue Oct 24, 2017 7:31 am
Gonna need some more information to help you. Are you printing from the SD Card or from a computer over the USB? What did you slice it in? Can you post your gcode so we can take a look?
Return to “Hacker Series - H2”
Who is online
Users browsing this forum: No registered users and 2 guests
