Delta Calibration Wizard now online
A place to talk about developmental stuff (firmware/software/hardware etc)
grat
Re: Delta Calibration Wizard now online
Postby grat » Wed Jan 10, 2018 4:23 pm
Yeah I contacted support over lunch and Ryan suggested the same and to try it again basically. So I went through the wizard for the 4th time and of course that time it worked as expected.
The results also fixed my bottom layer problems too!
fj..
Tonkabot
Postby Tonkabot » Fri Mar 16, 2018 11:57 am
I have a Max V2 with upgraded arms from Brian. What would I have to do to add this capability to my machine?
I assume I would need the accelerometer board and newer software in my Rambo... And then mount my head in that new board?
Brynn
ULTIMATE 3D JEDDI
Postby Jimustanguitar » Mon Mar 19, 2018 8:17 am
Tonkabot wrote:I have a Max V2 with upgraded arms from Brian. What would I have to do to add this capability to my machine?
Brynn
The accel board and newer firmware are the bare minimums for this all to work.
If your TrickLaser arms are a different length than stock though, know that the octoprint plugin won't work for you.
Tonkabot
Postby Tonkabot » Tue Mar 20, 2018 2:29 pm
My tricklaser arms are whatever the standard length they come as, I assume that is same as the original arms... I don't know.
What is the Octoprint plugin? what software does it plug into? I thought the Octoprint stuff had something to do with a raspberry Pi.
Brynn
Return to “Development Topics”
Who is online
