What are the benefits of upgrading my Rostock Max V3 to a V3.2
Cpaclee
Post by Cpaclee » Sun Jul 08, 2018 12:04 am
Hey guys, I love my Max V3, have printed hundreds of hours on it. Should I upgrade to the V3.2 and what are the benefits of it?
Iamarobot
Re: What are the benefits of upgrading my Rostock Max V3 to a V3.2
Post by Iamarobot » Wed Aug 01, 2018 4:59 am
Anyone have a respoonse? I'm thinking about upgrading to 3.2 as it looks like my heater cartridge is shot in my HE280, but want to know for sure that it's a worthwhile upgrade and would allow printing higher temperature materials reliably.
Post by geneb » Wed Aug 01, 2018 7:50 am
The largest benefit to the upgrade is the 32 bit Duet controller. You'll get excellent calibration, every time. You can also do rapid moves at 400mm/sec without losing steps.
Iamarobot
Post by Iamarobot » Wed Aug 01, 2018 2:21 pm
Thanks, geneb.
Any experience with the SE300 vs. the HE280 in terms of high temperature materials? Or is there a clearly better solution like an E3D V6?
Bogative
Post by Bogative » Sat Aug 11, 2018 12:33 am
Iamarobot wrote:Anyone have a respoonse? I'm thinking about upgrading to 3.2 as it looks like my heater cartridge is shot in my HE280, but want to know for sure that it's a worthwhile upgrade and would allow printing higher temperature materials reliably.
I am wondering the same thing with mine.. It can not hold temp once it hits layer 2 and the fans come on. Slowly drifts down and I tried redoing PID cal. I also tried doing PID cal with fans on but never got to temp. Assume heater cartridge.. Cheap enough to get new one and test but was also considering the upgrade if I could find a good reason.
Iamarobot
Post by Iamarobot » Sat Aug 11, 2018 1:19 am
I went ahead and got the upgrade kit, and am doing a first test print now. So far, it is insanely much quieter and seems to handle speed better. The Duet browser control has a lot of nice features and information, and the calibration is much more thorough.
Did I mention how much quieter it is?
I have to set up Cura so that I can really put it through its paces this weekend and next week, but so far so good. I was using Mattercontrol with the V3, which was fine, but I do prefer Cura.
Check your 12AWG power wires into the Rambo board - I had loose wires into the board which I think is what started my issues with hot end temperature stability. I don't know if that led to a fried heater cartridge, or if it was coincidental to that problem, but when I checked one of the wires just fell out of the terminal block.
Bogative
Post by Bogative » Wed Aug 15, 2018 7:45 pm
Iamarobot wrote:I went ahead and got the upgrade kit, and am doing a first test print now. So far, it is insanely much quieter and seems to handle speed better. The Duet browser control has a lot of nice features and information, and the calibration is much more thorough.
Sounds good.. I don't want to spend the $600 right now as I would have to add touchscreen controller as well. Noise is a non-issue for my location. Ordered 2 heater carts but I will check the wiring when I get back in town. I would like to get it back in service my Prusas have been running almost non-stop so I need another printer going.
MrWiggum
Post by MrWiggum » Mon Nov 05, 2018 1:07 pm
Could you upgrade v3 to v3.2 without the duet and keep printing using the board that came with the v3?
Post by geneb » Tue Nov 06, 2018 9:01 am
Without the Duet board, you're not upgrading, you're just swapping out hot ends - to one that the RAMBo can't use for auto-calibration.
MrWiggum
Post by MrWiggum » Wed Nov 07, 2018 1:15 pm
Good to know, thank you, that means it's time to buy the bundle :D :D
Post by geneb » Thu Nov 08, 2018 7:44 am
You won't regret it. The auto-calibration is nearly witchcraft-level good and watching a Rostock MAX rapid move at 400mm/sec is something to see. ;)
MrWiggum
Post by MrWiggum » Thu Nov 08, 2018 11:33 am
400mm that's insane, scary insane, can't wait to see it. Any guides should I follow when calibrating the new 3.2 update?
Post by geneb » Fri Nov 09, 2018 8:09 am
The docs should cover it, but you basically hit the calibrate button and it'll do its thing. ;)
MrWiggum
Post by MrWiggum » Thu Nov 29, 2018 3:34 pm
So I've upgraded to 3.2 and I will never looks back. I Iove it, only one thing I am concerned about which is my fault but still wanted to ask. I bought the Ethernet version of the duet board and the 3.2 upgrade came with a wifi faceplate for the front of the 3d printer, the one where the mini SD card is located. Because the Ethernet port sticks out more it won't fit with the wifi faceplate. Does anyone know where or if they make an Ethernet faceplate to cover the open hole?
Post by geneb » Fri Nov 30, 2018 7:27 am
I would contact support about that.
MrWiggum
Post by MrWiggum » Mon Dec 03, 2018 4:06 pm
So support gave me the STL file to try and remix it myself or ask someone to do it for me. They don't sell the Ethernet and they machine the plate themselves so it makes sense. I appreciate they gave me the file so now I am going to learn how to edit it :D
Return to “Rostock MAX v3”
