PCB Board Rev 6a
Morriz
PCB Board Rev 6a
Post by Morriz » Wed Feb 14, 2018 10:13 am
Anyone has PCB Board Rev 6a schema?
Pin voltage / use?
Thank you,
Marcello
Re: PCB Board Rev 6a
Post by geneb » Wed Feb 14, 2018 10:38 pm
Can you clarify what "rev 6a" pcb you're talking about? :)
Morriz
Post by Morriz » Thu Feb 15, 2018 4:53 am
This one:
https://www.seemecnc.com/collections/pa ... -pcb-board
that is different from rev 5a schemes on GitHub site.
Post by geneb » Thu Feb 15, 2018 8:23 am
Morriz
Post by Morriz » Thu Feb 15, 2018 8:36 am
I saw that on new Rev 6A of PCB there're new 2 pins socks named PROBE, LED and 3 FAN PART than 1.
What is the use of PROBE? Voltage In/out?
Voltage Out of LED? Always ON?
Thanks,
Marcello
Post by geneb » Fri Feb 16, 2018 4:15 pm
I'm not sure what the changes are related to - I don't have one of the newer boards.
pouncingiguana
Post by pouncingiguana » Sat Feb 17, 2018 3:48 pm
The probe pin locations are not used.
The LED pins are always on hooked to the main power for the hot end (nom 12v always on).
The three part fans are wired in parallel with each other.
The Heatsink fan is wired to the hot end main power (always on)
Morriz
Post by Morriz » Tue Feb 20, 2018 4:39 am
Thank you pouncingiguana
Marcello
Return to “Rostock MAX v3”
