OctopPrint not connecting
The new for 2016 Rostock MAX v3!
sfuelberth
Post by sfuelberth » Tue Oct 17, 2017 1:48 pm
So I upgrade OctopPrint to 1.3.5 and now when OctoPrint is trying to connect it hangs, also it seems that the printer is returning garbage. Has anyone seen this? I can control the printer just fine through the LED screen, so I am not really sure what is going on here. Thanks.
Connecting to: /dev/ttyACM0
Changing monitoring state from 'Offline' to 'Opening serial port'
Connected to: Serial<id=0x6d3b2270, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection
Changing monitoring state from 'Opening serial port' to 'Detecting baudrate'
Trying baudrate: 115200
Send: N0 M110 N0*125
Recv: �n�\x16��\x7f;}\x03]�k�^�>6
6q
Recv: \x15�J�I�JHJ�
Recv: j�\x1f�?��\x1f�
Recv: j��\x1f��j��\x1f��j�\x1f����\x1f��:�M\x0f\x02��l\x7fa^!hHHJ�j\x08N��a�*��\x7f\x04�/�_]�:XI\x03Ha�{\x0e\x16\x7fV~�\x0eHgH\x0f�H6\x13�\x0c'Ho�HV\x13�\x0c'Ho�HV\x13�;�6J�
Recv: _S�;�V
Recv: �\x08_\x13�\x0c'Ho�hV\x13�,'H/�h\x16\x13HH'Ho�HV\x13hHgH\x0f�h6\x13�\x0cgH\x0f�H6\x13�\x0c'Ho�HV\x13��~\x16J�
Recv: _\x13�,\x07H/�h\x16S��^V
Recv: \x03\x0c_\x13�\x0c'Ho�HV\x13�,'H/�h\x16\x13��~\x16J\x03\x08_\x13�,\x07H/�h\x16SH�>V
Recv: \x03\x08_\x13\x08HgH\x0f�h6\x13h�~6jC
Recv: _\x13HH\x07H/�h\x16S��>\x16
Recv: \x03\x08_\x13�\x0c'H/�h\x16\x13\x08�^Vj\x03\x08\x1f\x13hH\x07H/�h6S��~\x16J\x03
ULTIMATE 3D JEDDI
Re: OctopPrint not connecting
Post by geneb » Tue Oct 17, 2017 5:09 pm
The baud rate should be 250000.
tehwadeski
Post by tehwadeski » Thu Dec 28, 2017 7:11 pm
Thanks for posting the baud rate! Older version of octoprint would detect the baud rate on its own. Explicitly setting the 250000 value fixed my connections issue.
Thanks again.
ULTIMATE 3D JEDDI
Post by geneb » Fri Dec 29, 2017 12:51 pm
You're welcome!
Return to “Rostock MAX v3”
