Raspberry Pi Installation Instructions
The new for 2016 Rostock MAX v3!
Burley
Post by Burley » Mon Oct 24, 2016 5:19 pm
Is there some supporting documentation on how to do a step by step install of this option? I'd like to be able to use the V3 as a wifi network printer.
Jim
ULTIMATE 3D JEDDI
Re: Raspberry Pi Installation Instructions
Post by mhackney » Mon Oct 24, 2016 6:44 pm
Did you look in my V3 build thread? It actually starts with the RPi and OctoPrint install and then throughout the thread additional info is posted:
viewtopic.php?f=42&t=10836
ido3dprintz
Post by ido3dprintz » Mon Oct 24, 2016 8:51 pm
Handy write-up for sure. I especially like the EEPROM add-on for reading the values. The auto-cal script doesn't work for me since the directory structure is different for some reason but overall., it helped me get my PI it up and running. Now I just need to find out where to power it without using external micro USB port.
8-) n00b in training, willing to learn and absorb all that I can for this hobby 8-)
Burley
Post by Burley » Tue Oct 25, 2016 7:29 am
mhackney wrote:Did you look in my V3 build thread? It actually starts with the RPi and OctoPrint install and then throughout the thread additional info is posted:
No, I didnt. I used the posted build instructions as that was what was available when I put it together. Does the install allow the printer to be autonomous and not use some external service?
lightninjay
Post by lightninjay » Tue Oct 25, 2016 8:02 am
The Raspberry Pi is solely a stand-in replacement for your computer as a printer host. It does not even HAVE to run octoprint. Technically speaking, you could run whatever operating system you want on the Pi, as long as that OS has software which can communicate with the printer.
Octoprint is basically like repetier-host (or more accurately, Repetier-Server) in that it takes the Gcode you feed it, and then it feeds it over USB to the LCD controller, which then proceeds to print the same as if you had started a print in Repetier-Host, MatterControl, or from the SD card. The main difference in Octoprint is that you can connect to Octoprint remotely, which is then going to run your printer locally.
ULTIMATE 3D JEDDI
Post by geneb » Tue Oct 25, 2016 8:58 am
mhackey's write up is awesome, but didn't you see the installation instructions for the Pi that are part of the build?
pswindler
Post by pswindler » Wed Oct 26, 2016 2:32 am
i put detailed instructions for powering the pie off the rambo in the "extra Wireing?" topic under rostock max v3
Return to “Rostock MAX v3”
