Auto Cal and PEI
The new for 2016 Rostock MAX v3!
TwoTone
Auto Cal and PEI
Post by TwoTone » Sun Sep 18, 2016 12:19 pm
At some point if any of the V3 owners that use PEI on the glass could comment on how well the PEI is holding up to the hot end hitting the bed I'd appreciate it.
Thanks.
ccavanaugh
Re: Auto Cal and PEI
Post by ccavanaugh » Sun Sep 18, 2016 12:30 pm
PEI holds up fine to FSR probing and is a relatively hard surface. It should be fine.
ULTIMATE 3D JEDDI
Post by mhackney » Mon Sep 19, 2016 11:49 am
ccavanaugh got it right. There is no problem poking a hot nozzle into PEI momentarily for probing. I do it multiple times every day and have for several years. No marks on any of my PEI beds from that. I would not leave it touching the PEI, especially at elevated temps (>225°C) for any length of time.
I also just got an email from PartDaddy that said that probing with the accelerometer probe on the V3 is done at room temperature, so no problem with that at all!
adarcher
Post by adarcher » Mon Sep 19, 2016 12:58 pm
I've been pretty mean to my PEI and it's still fine.
Even with a single scratch (that came with it in the mail) I haven't had any problem with adhesion--though there is a small line in the bottom of the part usually.
TwoTone
Post by TwoTone » Mon Sep 19, 2016 1:16 pm
Thanks for the replies. I was just a little concerned. We had a mistake made while setting Z height and the hot end messed up the PEI pretty bad.
ULTIMATE 3D JEDDI
Post by Jimustanguitar » Tue Sep 20, 2016 8:07 am
For mechanical probing, it should be just fine. The only time that I've heard of PEI causing probing problems is with the infrared sensor that the Duet can optionally use. PEI is transparent to that spectrum of light, so folks have painted the back side of their PEI black before installing it.
ULTIMATE 3D JEDDI
Post by mhackney » Tue Sep 20, 2016 8:55 am
That is true Jim. And I just recently discovered that the CA patching technique I developed to repair PEI is not compatible with the IR probe and will give erroneous results.
Return to “Rostock MAX v3”
