BuildTak mounting on Max V3?
The new for 2016 Rostock MAX v3!
ROvermeyer
Post by ROvermeyer » Mon Aug 05, 2019 1:46 pm
How do you mount the BuildTak system on the Max?
The glass build plate, the magnetic mounting base, which is adhered to the build plate, and the flexplate are all 12” in diameter? The glass build plate with the attached magnetic mounting plate should be held in place with the bed clips. When the bed clips are turned in it reduces the size of the build area. Since the flexplate is the same size as the build plate and mounting base the bed clips prevent the 12” flexplate from sitting on the mounting base.
So, how have others gotten around this issue?
Bob O.
ULTIMATE 3D JEDDI
Re: BuildTak mounting on Max V3?
Post by Mac The Knife » Tue Aug 06, 2019 7:31 am
By avoiding the clips when positioning the print in the slicer program.
Return to “Rostock MAX v3”
