Enclosure for 7" Panel Due
DerStig
Postby DerStig » Tue Jan 03, 2017 1:27 am
I saw a enclosure for the 7" screen that fit in the Rostock Max V2 original LCD bay. It was also tilted. Anyone remember that one? I'm looking to print it.
Thanks
ULTIMATE 3D JEDDI
Re: Enclosure for 7" Panel Due
Postby Jimustanguitar » Tue Jan 03, 2017 1:30 am
DC42 has one. He is the Duet and Due guy, after all.
http://www.thingiverse.com/thing:656884
DerStig
Postby DerStig » Tue Jan 03, 2017 2:19 am
That ones not it, I found it searching
http://forum.seemecnc.com/download/file.php?id=11783
crocky
Postby crocky » Tue Jan 03, 2017 4:32 pm
It suits what I have in mind as well...
Looks like it must have the pcb mounted with a extension cable or maybe it is off-center... there must be a cover that goes on the front of it?
Bob
Delta's are the way!
DerStig
Postby DerStig » Tue Jan 03, 2017 6:21 pm
crocky wrote:It suits what I have in mind as well...
The mounts for the PanelDue driver and the Duet are in the "snorkel" plus there is a cover, I forgot to link it
http://forum.seemecnc.com/download/file.php?id=11747
Outsider
Postby Outsider » Tue Jan 03, 2017 8:29 pm
you have version 2.4
here is a copy of version 2.6
your faceplate is version 1.5
here is version 1.8
PanelDue and Duet Faceplate V2 Version 1.8.stl
(4.89 MiB) Downloaded 34 times
CRPerryJr
Postby CRPerryJr » Tue Jan 03, 2017 10:20 pm
SeeMeCNC Rostock Max V2
Makerbot Replicator Gen 5
3D-Print
Postby 3D-Print » Tue Jan 03, 2017 11:29 pm
Here is how I attached the Due and Duet using the mount.
viewtopic.php?f=42&t=7303&start=100#p85491
crocky
Postby crocky » Wed Jan 04, 2017 12:33 am
Outsider wrote:you have version 2.4
PanelDue and Duet Base for ROSTOCK Max V2 - Version 2.6.stl
here is version 1.8
Thank you..... :) and 3D Print?
Bob
Return to “Duet”
Who is online
