Resistor Wire
A place for the physical connections
KyleSandwichman
Resistor Wire
Post by KyleSandwichman » Thu Apr 19, 2012 4:01 pm
I would like to know what wire people are using to connect to the heating resistors. It seems that a bunch of people are using some kind of teflon/ptfe insulated wire, but I have read about other builds that just use regular wire and have had no problems. The electronics guide just says 4 conductor wire, but that's not very informative. Please also include where you got your wire from as I have had trouble finding some of these parts in the past. Thanks!
michaellatif
Re: Resistor Wire
Post by michaellatif » Thu Apr 19, 2012 4:16 pm
Hi Kyle,
I have 18awg stranded, 2 core wire - source for this was home depot, basic lamp wire, clear/silver sheathing color. Nothing fancy. I just keep the wire from touching any of the heated parts and it has been doing fine. I purchased it from the electrical section that a HD worker would have to measure and cut for me.
Mike Latif
H-1 #3
ULTIMATE 3D JEDDI
Re: Resistor Wire
Post by Polygonhell » Thu Apr 19, 2012 5:14 pm
I'm using ordinary 18 gauge wire, crimped onto the resistor leads, no issues with it again I just keep it away from the actual heated part.
I would recommend having some sort of connector close to the actual hot end, it makes removing it much easier when it jams.
I use a 4 pin molex connector.
PJgearhead
Re: Resistor Wire
Post by PJgearhead » Sun May 27, 2012 8:02 am
I just run standard double insulated automotive two core wire thats soldered to the end of one of the resistors, then the second resistor is crimped to the first.
Return to “Nuts and Bolts”
